Overseed? Re-Seed?
   / Overseed? Re-Seed? #1
JLoaf
White Co., ARKANSAS
Kubota L3830 DT & B2710
About 10 years ago I was living at a different house, I tilled an area of my yard and seeded with burmuda and centipede grass. The burmuda came up the 1st year and the next year centipede took over.
In my experience, centipede is better turf grass. It's seems to choke out weeds better, does well in sun or shade, and is more drought tolerant.
My lawn now is burmuda and I would like to have centipede grass.
I would rather not re-sod or till the yard.
Is there an attachment that will allow me to get centipede seed into my existing lawn without tearing it up?
   / Overseed? Re-Seed? #2
It's called a "slit seeder". (power seeder) I believe Landpride sells one, but I may be all wrong there. Toro makes one that's popular with the golf course people. It uses a series of "saw blade" looking wheels to make a slight cut in the turf, then drops seed in the cut. A press wheel firms soil over the seeded cut.
There are also smaller walk-behind models. In this area, Home Depot rents them.
   / Overseed? Re-Seed? #3
As FWJ said, a slit-seeder is what you want, but I would do it in the fall.
Thanks for the info. I think a "slit-seeder" is exactly what I need.
   / Overseed? Re-Seed? #5
It's not going to be cheap
Look into renting one.
   / Overseed? Re-Seed? #6
I'm surprised that anything would choke out common bermuda. Around here, just the opposite is true. People will have a nice centipede yard, and before they know it, it will be choked out by bermuda.
I've talked to several people that have seeded a combination of bermuda and centipede. Bermuda comes up faster and stabilizes the soil to allow the centipede seed to slowly germinate and take root.
I don't know if it is a good idea for every location? I do know it worked well in south Arkansas - at least once.
I do intend to rent (not buy)the slit-seeder. I have too many toys already.
   / Overseed? Re-Seed? #8
I wondered why I had never hear of Centipede Grass so I looked it up. It appears to be a low quality grass that is only suitable for some of the warmest areas of the US. According to this report about it it is not suitable for high traffic areas. It appears to be a very coarse grass.
Centipedegrass
Andy
   / Overseed? Re-Seed? #9
Centipedegrass
Andy
I'm surprised you've never heard of centipede: in the south, it reigns supreme as a lawngrass. Wears VERY well under heavy traffic. Creeps along and fills in bare spots. It is not as course as St. Augustine, and is only slightly more coarse than KY 31 grows here. Up in Connecticut maybe you see a lot of red fescue or creeping fescue? Those grow ok here if you plant them in the fall.
In order to overseed centipede over bermuda, take every other tine off your landscape rake, and scarify your bermuda ground. The disturbed soil will catch the centipede seeds in the next rain. There they will germinate and the following year compete wiht your other grasses.
The advice about planting centipede in the fall is a gross error. Fescue in the fall, centiped and bermuda in the spring.
   / Overseed? Re-Seed? #10
The reason we've never heard of Centipede grass up north is that it doesn't grow here. The grasses we grow around here become dormant in the winter and van be frozen. According to what I've read, centipede grass does not go dormant and hence is killed by freezing. Hey we can't grow citrus fruits here either. :D
Andy
Aluminum Bear (A57454)
30' E-Z Trail Head Cart (A59814)
30' E-Z Trail Head...
2002 International 9200i Truck (A56438)
2002 International...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
Toro Groundsmaster 400-D (A57453)
Toro Groundsmaster...
Electric Horseless Carriage (A57453)
Electric Horseless...
