Quick Hitches Overrunning Clutch Assembly and PTO
   / Overrunning Clutch Assembly and PTO #1
camkubotaguy
Toronto
Kubota T1600
I am serious about buying a B8200HST, but need some advice before I do. The model year is probably pre-1985 because there is no ROPS installed on it.
I was watching a video about this over-running clutch assembly for older kubotas, and the implication is that if you don't have one, you could damage your power internals. My question is, where can you buy these and what is the cost?
The other question i have is about the rear PTO. Does anyone know the direction of movement on this? Looking at the rear PTO from the back of the tractor, if it is turning CW, is this what I should be looking for? I have heard about some grey market tractors needing a PTO reversing gear, and did not want to make the purchase without knowing the facts about this.
Thanks for any input.
   / Overrunning Clutch Assembly and PTO #2
YOu can buy an external ORC that fits into the PTO drive line at Tractor Supply or similar places for less than $100. Rear PTOs turn CW viewed from the back of the tractor.
That B8200HST was manufactured between 1983 and 1990. It's a modern tractor, not an antique, and almost certainly has an internal ORC.
Good luck.
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2015 INTERNATIONAL...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
2016 Ford Explorer...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
