overheating Bolens/Iseki
   / overheating Bolens/Iseki #1
Scott in ME
Bolens/Iseki G154
Hi - I have another Bolens G154 question. I added a 48" wide snowblower to the rear and spent some time clearing snow from an area where it was deep and icy. The tractor got a workout, using the loader to know down icy hills and snow blowing until the engine was about to stall. After about 30-40 minutes of use, the red "hot" light would come on. I let the tractor cool down, checked the coolant level, fan, and belts, and went back to work. This happened a few more times. No coolant is coming out of the run off tube (attached to the nipple on the radiator neck), but there certainly was pressure when I cracked the cap (covered by a heavy towel). The only things I can think of are a clogged cooling system, gummed up radiator, or bad water pump (though it isn't leaking). That, or these tractors just don't like to be worked. Any suggestions welcomed.
   / overheating Bolens/Iseki #2
Make sure the fins in the radiator core are clear. You could have snow blocking the airflow. I flushed, then reverse flushed my cooling system. After that I used a product called Thermo Cure to clean out my Mitsubishi cooling system. It removed a LOT of built up crud. It was about $20 for a quart at Walmart. Follow the instructions and flush the system with clean water at least three times before refilling.
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
Unused 2025 CFG QK20R Mini Excavator (A50322)
Unused 2025 CFG...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
1987 Ford 2110 Tractor (A50514)
1987 Ford 2110...
