Overcharging problem on MT210D
   / Overcharging problem on MT210D #1
Goodtimze
Eastern CT
Kubota L3450
My MT210D seems to be overcharging the battery. I replaced the voltage regulator but the problem is still there. It charges at about 16.4 volts and when I shut off the tractor the battery is hissing. Has anyone had this problem before or know what else might be causing it.
   / Overcharging problem on MT210D #2
Have you had the alternator checked? If it has a problem it may be sending incorrect info to the regulator. Have you had the battery checked? It may have a short. Is the regulator the correct replacement? Is it wired correctly? Is the new regulator good? It sounds as if the alternator output is not being regulated. Have you checked and cleaned your ground connections at the chassis? If you would like to discuss this call 1-800-609-5110. Bill - satohparts.com
Bill,
Thanx for the info I will check these out and if I don't fix the problem I will give you a call. I appreciate the information. Also if you deal in used parts I'm looking for a front pinion shaft for the same tractor.
Thank You
Shawn
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2014 PJ 24+6 T/A GOOSENECK (A50854)
2014 PJ 24+6 T/A...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
