Overall Satisfaction with TN or TL models?
   / Overall Satisfaction with TN or TL models? #1
k9roccy
Indpls, IN
JD4700
For those of you who operate a TL or TN model with cab and loader. What is your overall satisfaction level with the tractor? Do these models have any design or quality control problems? Thanks for your input.
   / Overall Satisfaction with TN or TL models? #2
k9roccy,
I have a TN70D, with the 16x16 trans, MFWD, 32LA loader with quick attach, ag tires. This machine is a manual shuttle. The D denotes Cab and AC. It is even prewired for a radio, but that has not been a priority.
Can't say enough good things about this tractor. Virtually no problems at all other than a belt noise when it was new. Turned out to be excess paint on a pully; easy fix. Dealer drove all the way out to my place, quite a trip, fixed it for free no questions asked. Also did labour on the first service for free at my place, again a long drive.
I use it for hay production; running cutter, rake and baler, as well as moving bales. But it works well for clearing land and cutting fence rows, moving gravel or dirt, and grading roads, etc...
The neat thing about the 32LA quick attach is its bobcat compatible. My set of forks and hay spike where purchased from a Bobcat dealer not NH. Takes about 2-3 min to swap loader attachments maybe a little longer to line it up if its a very heavy attachment. Just lift two levers.
The TN is plenty of horse power for me. Some days I think it would be better to have a TL100 but it would be over kill, I can do it all with this machine.
If you get a 4wd TN stuck you are quite talented. I have used it to rescue a 4wd F250. Pulling a heavy dump trailer or fert buggy in soft ground is no problem. Will pull a full 4x5 baler up down and across 15 degree slopes even while baling up heavy hay windrows.
If I had to do again I would buy a TN.
I would not get the supersteer not necessary for me at least. I would get the three remotes, and while your at it the 75 model does not cost much more than any of the others and it gives you a higher hydraulic flow rate. I also don't see the need for the MSL. But thats just me your needs may be different. The only reason I got the 70 rather than the 75 was it was on the lot and a good deal.
Fred
   / Overall Satisfaction with TN or TL models? #3
</font><font color="blue" class="small">( If you get a 4wd TN stuck you are quite talented. )</font>
I am talented /forums/images/graemlins/smile.gif That means my parents didn't lie /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
The TN's are great machines. As far as I know all the bugs and Quality control items were worked out the first couple years. I do not have a cab on my 65 but that was not a priority at the time and for what I do I most likely would have destroyed just about every window in it by now /forums/images/graemlins/tongue.gif You will be happy with a TN if you choose one. I do not know about the TL but all I hear about it is good. Having never run one I can't say from first hand experience but I do not see people posting about problems on any of the boards.
   / Overall Satisfaction with TN or TL models? #4
Robert,
Maybe I will try a little harder this weekend.... /forums/images/graemlins/wink.gif
You have to admit that its not easy. I had mine with the tires sunk down in soft mud about a foot or more. Shifted down to a low gear hit the diff lock and it climbed right out.
Fred
   / Overall Satisfaction with TN or TL models? #5
I got mine stuck. I dropped off a concrete slab into belly deep mud and couldn't get it to climb back on the slab. It might have been because the box blade was sitting on it!
   / Overall Satisfaction with TN or TL models? #6
I agree, it was the first time it has been stuck in the 3 years since I bought it. This spring has been very wet and I buried it twice with the 12 disc on it. If the disc didn't bury so easily I might have made it but oh well.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
2011 Jeep Cherokee Laredo SUV (A50324)
2011 Jeep Cherokee...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
