Over-The-Tire Track questions.
   / Over-The-Tire Track questions. #1
Bob Rooks
Elite Member
Washington state
Yuchai Dozer (sold).
I can't seem to find definitive answers anywhere (so far), but:
Will OTT's have a significant impact on axle bearing and/or tire life expectancy?
   / Over-The-Tire Track questions. #2
Steel OTT or rubber? Steel shouldn't be too bad on your axles (don't use foam filled with steel tracks), but they can have a definite impact on tire life depending on your tire type. OTT Rubber tracks can have an effect on axles and require special tires. Your local dealer can help you match things up.
Sorry 'bout that omission sir. Rubber tracks (kinder to asphalt).:D
That raises a challenge - finding a knowledgeable dealer in my area, but you have confirmed my suspicion about the rubber tracks. :thumbsup:
   / Over-The-Tire Track questions. #4
I've also been looking at getting some OTT's for my skid steer. From everything I've read it seems as long as they are kept within the 1.5" to 3" sag{at top of track} they work fine. Are you looking at an all rubber track or something with replacable rubber shoes/pads?
I've been looking at all rubber (cable embedded) instead of links, thinking they'd be easier on the tires but it's hard to find a knowledge base. Local tire shops aren't much help, even the ones that handle construction equipment.
   / Over-The-Tire Track questions. #6
You can't use foam filled tires with rubber tracks either. My experience is that you don't need special tires with the rubber tracks. I did need spacers and center backspaced wheels to move the tires away from the chassis to make room for the tracks. This was on a 7-series Bobcat. I'm struggling to see how OTT tracks can accelerate bearing wear, maybe in long term high traction asphalt operation with a lot of single track pivoting, but then why would you need tracks. I think moving the tires out wider could cause more of an issue than the tracks themselves. I still don't think you'd be able to quantify the difference in wear. Is this a full time installation, or to get you through the winter? What brand of OTT tracks are you looking at?
Brian
Hi Brian,
Most of my operation is in glacial till (clay & hardpan with various sized rock) but I do have a ~1,000' paved "driveway" to maintain. I'm hoping that the tracks will be somewhat permanent. I avoid doing tight pivoting. I operate the SS like I operate the rubber tracked dozer - no turning on a dime unless absolutely necessary.
I'm looking at 10" Solideal tracks (have 10x16.5 tires), and yes, I will need the 2" spacers for frame clearance. My concern about bearing wear is that the lateral force loading of track tension will combine with the vertical (loaded machine weight) loading of the bearings, in effect exponentially loading them. The machine was not originally designed to accomodate OTT's. Maybe I'm just chasing a windmill though...:D
   / Over-The-Tire Track questions. #8
I'm not a big fan of Solideal. The OTT tracks I am familiar with were Solideal link type and I did not have a real issue with them. I did break one, but I was using them with foam filled tires, so I won't fault them for that. My issue with Solideal came with their replacement tracks for my other rubber track machines. Solideal's warranty is 6 months or 600 hours. I was buying 2 or more sets of tracks at a time to keep on hand because I was maintaining a fleet of Bobcat machines, I had 9 T180's, 1 T190, and 7 T300's. Because I was stocking my own tracks, at times I had them for months before they were installed, and they consider the date of purchase as the date of installation so they could be out of warranty before I installed them. Their other problem was they seemed to fail at about 600 hours of use. The factory rep would come out to do the warranty claim, admit that they failed, and in the same breath tell me I was out of luck because they were out of warranty. If they had worn out at 600 hours I could have dealt with that, but they were failing, and by they, I mean several. I think of the 6 tracks that I tried to get warranted they replaced one, and pro-rated another and gave me a $100 credit. I quit using Solideal and was much happier.
Brian
Okay Brian, that's a very compelling argument. What rubber tracks would you recommend?
I guess a better way to phrase that would be; what brand are you using now?
   / Over-The-Tire Track questions. #10
I had an 873 with tracks. It seemed to me that they caused more harm than good. Mine were steel though, but they were not worth the cost if purchased seperately. The machine that I had came with them.
Front tires were put under more strain when backing uphill with a full bucket. This would cause the tires to come loose from the rim. This happened more than once.
Tires had to be deflated to install tracks, then reinflated.
Rims had to be swapped side to side to provide more backspacing. This put the valve stem on the inside which was a headache.
They just didn't provide enough extra good to out weigh the bad in my opinion.
2016 Ford Fusion S Sedan (A44572)
2016 Ford Fusion S...
John Deere 6135E (A44501)
John Deere 6135E...
WANCO 6K LIGHT TOWER (A45046)
WANCO 6K LIGHT...
Deere 27G Mini Excavator (A44501)
Deere 27G Mini...
2005 IMS 5012 LP VERSI DREDGE (A45046)
2005 IMS 5012 LP...
John Deere 5075E (A44501)
John Deere 5075E...
