Rotary Cutter Over run clutches
   / Over run clutches #1
transformer
Trinity, Al.
Yanmar 2000
I have a yanmar 2000 an a 4' bush hog and a over run clutch to keep the bush hog from pushing me into trees and stuff when i push the clutch in. the over run clutch is the quick connect type since the yanmar does not have a hole in it's pto i have to use this type. any way, while using the bush hog the other day the clutch came apart don't know why i have all the parts except the little springs and(3) of them and 3 roller or ball bearings if i could find out where i could buy these, i could put it back together. but i have asked tractor supplier's and googled with out success so i had to buy a new one for $75.00 it is a shame that I can not find parts. has any one had this to happen or do you you know where i might find parts for this clutch which has no information of what brand name or model or any info. thanks in advance for any info you can provide.
   / Over run clutches #2
I don't know the sizes of your springs, obviously, but Home Depot has a wide assortment of springs for sale online. They'll ship free to your store. Most give spring length, diameter, and wire diameter used to wind the spring. I suspect you're after compression springs.
   / Over run clutches
Thanks Roadworthy, I may have to take my new one apart and take some measurements because when this thing came from together it was turning 540 RPMs can, not find the springs and i don't know if the bearings were round or cylinder type but if i take the new one apart might be able to get measurements that way. i was hoping some one knew where to get parts specially for these over run clutches, it also has a special big washer and big Snap ring that looks ok but i would replace if i could find them also i was hoping to find a rebuild kit if there was one but if not, you gave me an idea of another route i can take.
   / Over run clutches #4
I have a Caroni (Italy) over run clutch from Agri Supply
It is a fine looking piece of machinery.
I do not ever expect it to fail.
JOHN DEERE 8410T TRACTOR (A51243)
JOHN DEERE 8410T...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
