Over Filled Hydraulic Reservoir
   / Over Filled Hydraulic Reservoir #1
franklyspeaking
On my Shibaura SP1540 I overfilled the hydraulic reservoir. Will this hurt anything?
   / Over Filled Hydraulic Reservoir #2
If you have a manual.. check it. Some hyd resv's are made so that they can be over filled a bit .. for instance if you have remotes that use alot of oil.. with cyls extended.. you still need the 'minimum' oil in the sump.. but when retracted.. you have some overfill.
My old 1955 ford 660 owners manual states that you can over fill by x quarts.. etc. same with my 2002 NH 7610s... Still.. I'm guessing the ability to safely overfill is tractor model specific. Unless you can find it in writing or from a knowledgeable dealer/mechanic.. I wouldn't overfill it.
Soundguy
   / Over Filled Hydraulic Reservoir #3
How much over fill , on the dipstick 1/2 " ?? /forums/images/graemlins/confused.gif
1 gallon. I bought this thing with no manual and can't read Japanese...didn't know where the dipstick was. I was having problems with the hydraulics and wanted to make sure it had enough oil, so I dumped in a whole gallon. I later found the dipstick and now see that it is way over the full mark. The hydraulics problem was resolved by making sure all of the switches are set correctly on the control box. I figured it was similar to power steering reservoir where too much doesn't hurt anything, but wanted to make sure.
   / Over Filled Hydraulic Reservoir #5
well just drain a half gallon out & see where the dip stick reads
thats easy enough to do.
Ernie
   / Over Filled Hydraulic Reservoir #6
Ernie , Are you trying to be a smarty or something? LOL!!
   / Over Filled Hydraulic Reservoir #7
Many tractors have a fill level plug on the side of the trans/rear end case so you can remove the plug while filling and when oil starts running out, you are done. It will be messy but you can remove that plug if you have one and let the oil drain down to it's proper level, put the plug back in.
What brand and model of tractor?
   / Over Filled Hydraulic Reservoir #8
The SP1540 doesn’t have the level plug option
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
(4) Goodyear 67x34.00-26NHS Tires (A50123)
(4) Goodyear...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
2018 Mitsubishi Mirage ES 4D Hatchback (A53117)
2018 Mitsubishi...
