Over cooling in the cold
   / Over cooling in the cold #1
wade simpson
dartmouth nova scotia
kioti ck20s
I have a ck20 and noticed the other day that the engine temp indicator was showing the engine was cold when the tractor was idling. It had been running for a few hrs. The ambient temp was around -5 C. I put some tar paper in front of the fan and it was fine.
Anyone else noticed this?
   / Over cooling in the cold #2
I think you need a new thermostat. mabee like a 195 degree although I dont know what a ck20 is is it water cooled?
   / Over cooling in the cold #3
At -5C?....23 degrees is not really cold enough to cause that. My tractor warms up to temp in about 5 min even in the teens. If covering the rad gets it to the proper temp then I would continue to do that.
   / Over cooling in the cold #4
My CK 30 no longer even registers on the temp gauge, although yesterday was -20. By the time the temp hit 0, I was barely registering on the gauge. It's on the new list of issues to discuss with my dealer.
   / Over cooling in the cold #5
On my smaller TZ25 I used to have a weatherfront. My T2220 doesn't seem to bother. Some diesels, at idle, do not burn enough fuel to create the heat. That's why you'll see many trucks at a high idle while at rest this time of year.
   / Over cooling in the cold #6
My CK30hst acts similar when the temps get to less than 20'F but I believe it's because of what Haymaker mentioned. While plowing snow, working the tractor with the rpms up at 2,000 or more, the temp gauge is at the mormal range. Let it idle for 10-15 minutes and it's down on the cold side but comes right back up after a few minutes of more work. After six years of Winter plowing, that temp drop at idle never caused a problem.
   / Over cooling in the cold #7
Cold temp idle is 1200/1400 for me
   / Over cooling in the cold #8
Could be a faulty sender unit causing the readings to be off at idle.
Until you know what it is I wouldn't cover the radiator. Better to have it running 'cold' on the gauge and possibly actually running correctly internally than trusting the gauge and artificially causing possible overheat condition.
My 2 cents.
The over cooling only seems to happen at idle, once I start working the temp comes up again. When I said cold I should have said just below the normal operating range..although I haven't let it idle for very long (10 -1 5 min). I considered a new thermostat but if the paper works..it's a lot cheaper and easier to install.
Thanks for the info fellas
   / Over cooling in the cold #10
Normal.
Start it, let the oil circulate for a few minutes, and then work it. That's the only way you will build and maintain heat in the motor.
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2012 John Deere 7230R (A52748)
2012 John Deere...
2012 FREIGHTLINER CASCADIA (A52472)
2012 FREIGHTLINER...
20ft Bumper Pull Equipment Trailer (A51572)
20ft Bumper Pull...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
