Outgrew TC33, need more hp , pto capacity and cab
   / Outgrew TC33, need more hp , pto capacity and cab #1
Dirtball
Eastern, Pa.
NH TC33D
What model over the TC45 would be good. Need 4wd , hydro or equivalent tranny, loader , turf tires want to pull 15-17 ft batwing finish mower. HVAC cab would be great....thanks for any help.
   / Outgrew TC33, need more hp , pto capacity and cab #2
If you are stepping up significantly in HP and size beyond a CUT and into the AG utility size tractor, hydro transmissions are very rare. Power reverser geared transmissions are the norm. Adding power shifting between gears is a popular option.
   / Outgrew TC33, need more hp , pto capacity and cab #3
With that size mower, depending on what you're cutting, you probably want 50 hp or better turning the PTO. Like dirtball said, that's utility tractor size, not compact. If you don't need 4wd, look into used Ag equipment. You might find 70 to 90 hp stuff is cheaper than the sub 50 hp size, especially if you go used.
   / Outgrew TC33, need more hp , pto capacity and cab #4
15-17' batwing.. and ac.. I'd deffinately look into utility or used ag tractor. I'd try to get over 50hp.. otherwise it is going to be an uphill climb if you clip more than a few dasies.. weight is also a concern with large mowers.. etc. I know you plan on pulling a finish mower.. not a rough cutter.. but still.. you need some hp...
Soundguy
   / Outgrew TC33, need more hp , pto capacity and cab #5
</font><font color="blue" class="small">( I'd try to get over 50hp )</font>
Yep.. what did Gatorboy use to pull his batwing mower?
   / Outgrew TC33, need more hp , pto capacity and cab #6
I looked at the specs for a number of 15 foot bat wings. The min required hp was 60. As far as I'm concerned running amower with minimum power is asking for trouble. I would sya you are looking at a TN75 or higher.
Andy
   / Outgrew TC33, need more hp , pto capacity and cab #7
I think that's good advice. For kicks.. I've powere up my 15' rough cut batwing with my ford 5000, and it has 67 pto hp.. but it just doesn't feel the same as my 7610s powering the 15'.. deffinate power difference with that extra 23+ hp.. etc. The 5000 really much prefers the 10' mower... anyhow.. back to the original posters issue.. One thing.. He is powering a finsih mower.. not a roung cutter.. I wonder how that factors in with hp requirements?? Do the batwing finish mowers require more or less on average hp per foot??
Soundguy
The Woods 9180rd 15ft finish mower is 3100lbs , 700lb tongue weight during transport and min. hp is 35.. I would never use a TC 40-45 for this . I am not familiar with the next models up the ladder in blue, green orange. After buying a TC25 and trading it with 10hrs for a TC33 , I don't want to buy too small.
   / Outgrew TC33, need more hp , pto capacity and cab #9
I have nothing to base this on but limited logic, but I would guess that a finish mower needs more hp than a rough cut bush hog type. The blades probably have to spin faster, the grass is more dense, you need to think about discharge in a more controlled manner, etc. I'd guess about 10 to 15% more hp minimum, size for size.
   / Outgrew TC33, need more hp , pto capacity and cab #10
</font><font color="blue" class="small">( The Woods 9180rd 15ft finish mower is 3100lbs , 700lb tongue weight during transport and min. hp is 35.. )</font>
My guess is 35 hp will make the blades spin.. and that is about it.
</font><font color="blue" class="small">( I would never use a TC 40-45 for this . I am not familiar with the next models up )</font>
48/55/60/70/80/100 ( some tc.. some tn - and others.. and sub models/options.)
Soundguy
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
