Outer Air Filter, 1455v
   / Outer Air Filter, 1455v #1
Glenn9643
Veteran Member
New Hebron, MS
MF 1455v 4wd, 1040FEL
I priced the outer air filter for a 1455v at my dealer today... $70.00. Mine isn't in really bad shape, but I've worked in a lot of dust through the summer and thought it wouldn't be a bad idea to change it, but at these prices??? Can these filters be bought from other suppliers that will work? I'll certainly check it out, but thought I'd complain here about the price.
   / Outer Air Filter, 1455v #2
Glenn,
Check with Jack's Small Engines. They are usually about 20% lower than list. Also check your manual, It tells how to clean the filter.
   / Outer Air Filter, 1455v #3
Hey Glenn, like Jerry said, the outer filter can be cleaned many times before it has to be replaced. The outer filter catches most of the larger particles and the inner get's whats left.
As long as you don't get it wet or blow holes in it by using to much compressed air, it will last a long time. Check your manual for maintenance recommendations.
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
Comfort Chute H Series Hoof Trimming Trailer (A50774)
Comfort Chute H...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
