Outdoor wood furnace
   / Outdoor wood furnace #1
dlabrie
Campton, NH
Kubota B2910
I was talking with the man who will install the Cenrral Boiler , if I have it done. He said he would hook it up directly to my FHW boiler, hence making the system non-pressurized. He said a circulator would run continuously from the outdoor furnace to the indoor FHW furnace, keeping the indoor furnace at operating temp. I have a DHW coil in the oil furnace so that would be covered as well.
I asked about corrosion issues. He said it wasn’t a problem, because they put in an additive to cover that.
I wondered what it would cost to run a circulator full time as well.
He also discouraged using a forced air vent on the outdoor furnace.
Does anyone have a set up like this? Is this the best way to go about it?
Thanks for the link. I read through them all But I can't seem to find one set up like I described above. Does that sound OK to you?
   / Outdoor wood furnace #4
Sorry, I ran out of time yesterday.
My setup runs a pump for my radient heat, Its a small pump and running the regular furnace pump vs that pump should be a small difference if any.
If, by forced air, you mean for the draft, you dont need it. If you meant forced hot air heat, they work fine.
One of the guys CB furnaces I looked at was hooked to a old HW system. It seemed to work for him.
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2004 Honda Pilot SUV (A50324)
2004 Honda Pilot...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
