Ouch! Cooling fan $$
   / Ouch! Cooling fan $$ #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Well, after troubleshooting the circuit it appears the cooling fan on my PT-425 is bad. It had been making noise -- sounding like the blades were rubbing something with no visible obstructions. Now it doesn't work at all, even jumping it directly to power...
So, I just ordered one from Tazewell for $172.38 to be delivered Thursday. I don't have time/easy access to try finding another aftermarket one that might fit -- I need to use the machine this weekend!
I tried searching and found a couple of old posts about fan failures. How frequent does this happen? My PT is approaching 400 hours now...
   / Ouch! Cooling fan $$ #2
I am sorry you had trouble with your cooling fan, and the price you had to pay for a new one. I have replaced mine from an auto cooling system fan They are practically the same, some smaller, some larger. You may not have the time to look for one, but the auto junk yards are full of them.
   / Ouch! Cooling fan $$ #3
Like JJ said the junk yards are full of them. I didn't know it at the time but when I first got my PT I put around 50 to 100 hard Sumer time hrs. on it wondering why the fan didn't kick on (a blown fuse). I fixed that and after another 200 hrs. I have not noticed any damage to the PT. I know I wouldn't advise it either but it was nice to know that the PT was designed well enough to take it.
Hay, time is money too, no telling how long it might have taken to find one at the junk yard. Enjoy the convenience of the new fan coming to your door.
</font><font color="blue" class="small">( Hay, time is money too, no telling how long it might have taken to find one at the junk yard. Enjoy the convenience of the new fan coming to your door.
)</font>
Yeah, especially when my PT is 900 miles away, I can't readily do "measure and search" or "trial and error." I had a friend, a mechanic, do the troubleshooting long distance, at least... so that I could order the replacement and can quickly install it when I get there and go to work...
Now, at least I'll have the bad one to take in search of other replacements...
   / Ouch! Cooling fan $$ #5
I picked up 3 spares for mine at $10.00 each. They could also be used for other projects. I have access to many junkyards and flea markets.
   / Ouch! Cooling fan $$ #6
If anyone else ever needs one, I've got a new one in my garage that I never used. Fits a 425 and I assume 422. It's the same fan the factory uses. Let's just say I'll let it go for a lot less than a new one from PT. /forums/images/graemlins/wink.gif
</font><font color="blue" class="small">( If anyone else ever needs one, I've got a new one in my garage that I never used. Fits a 425 and I assume 422. It's the same fan the factory uses. Let's just say I'll let it go for a lot less than a new one from PT. /forums/images/graemlins/wink.gif )</font>
My typical luck -- and timing... /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
   / Ouch! Cooling fan $$ #8
Sorry about that. But I thought I'd post to save the next guy maybe. Could have been worse I guess. Try pricing an engine from them.
Well, PT delivered the parts in two days. The replacement was easily done -- remove four nuts -- though I had to splice in one wire connector. Mine had one male and one female in vinyl sleeves, while the replacement had two females in a plastic wiring block. Not a biggie...
The bearings on my old fan were definitely shot -- the blade would noticeably "catch" in one spot. Back in service without worrying about overheating! /forums/images/graemlins/smile.gif
2023 John Deere 324G Skid Steer (A53342)
2023 John Deere...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
