Ouch, busted a front tire
   / Ouch, busted a front tire #1
grandpawj
Lancing, TN
Farmtrac 535 W/ 5245 front end loader(turf tires), MFG 2006
Yep, I was filling in a neighbor's swimming pool with dirt and the two front tires fell off the inside edge of the cement pool and was resting on the frame. Used the bucket to lift the front and popped the clutch in reverse, when I did the turf tires hit the edge pretty hard. Anyways I am hoping I can put a boot inside and put in a tube. If not, I am lookin at prolly couple hundred for another tire.
   / Ouch, busted a front tire #2
OUCH FOR SURE! I HOPE YOU CAN TUBE IT ALSO! THERE WAS A FORUM ON FOAM FILLED TIRES...MAYBE SAVE YOU SOME MONEY THERE? HOPE IT ALL WORKS OUT FOR YOU!
NO GOOD DEED GOES UNPUNISHED FOR SURE!
   / Ouch, busted a front tire #3
Well - I would check to see if you can reseat the bead by airing it back up with a good air compressor.
wish a reseat was all there was to it. It has a hole in the side about the size of a toothpick. I was putting air in and while doing so, I felt a whisp of air blowing on my arm. It might be repairable with a tube if I didn't create too big a "hernia" when I banged it. I noticed the side looked like it was creating an airpocket.
Update: Got my wheels back this morning. The tire shop put new tubes in. Said the tire with hole in sidewall with tube is good for hundreds of more hours. They did me right too. Two 24X13.00-12 tubes $15 ea and $8.00 to put em in. With tax $50. I feel fortunate.
   / Ouch, busted a front tire #6
Well, name the shop! If they do good work, let your neighbors know.
SKIP's Tire Center, Supply North Carolina!! (910) 755-3314
2013 FORD Taurus (A50324)
2013 FORD Taurus...
2019 Nissan Sentra (A50324)
2019 Nissan Sentra...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2 Row Cultivator (A52128)
2 Row Cultivator...
2016 Ford Explorer...
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
