Other quick hitch implements for JD FEl?
   / Other quick hitch implements for JD FEl? #1
BloomingtonMike
Platinum Member
John Deere 3320
What are some other implements that work woth the JD quick hitch FELs? I have a 300X loader coming and was just curious what else I can attach to it. Also who are other 3rd party accessory vendors that have pieces that attach to the JD FEL??
   / Other quick hitch implements for JD FEl? #2
JD sells a fork set, and a loader mounted snowplow, as well as diferent sized buckets, and a 4in1 bucket...just to name a few.
Most other companies do not make anything to fit the JD style QA, but rather make things to fit the SkidSteer QA setup. Or they sell them plain and you have to make the fit, easily done as the hooks and pins are available through JDParts for about $32.00
   / Other quick hitch implements for JD FEl? #3
A company called ATI has a product called Tach-All that either replaces the proprietary JD QA with a skid-steer style QA or an adapter bracket that converts the JD AQ to a skid-steer QA. They also offer lots of attachments and attachment brackets.
Check out ATI's Tach-All website here.
Here is a picture of their JD QA to skid-steer QA adapter.
   / Other quick hitch implements for JD FEl? #4
ATI also has a pin style QA. To see it you have to download their full product catalog.
   / Other quick hitch implements for JD FEl? #5
I just remembered, JD has a bale spear also...
   / Other quick hitch implements for JD FEl? #6
Also, I noticed the new line of 300CX FEL's had a skid steer (Bobcat I am sure) bracket mounted directly, in place of the Deere quick-tach. Must be an option. With a third SCV, one could probably activate the locking mechanisms from the 'seat'.
</font><font color="blue" class="small">( A company called ATI has a product called Tach-All that either replaces the proprietary JD QA with a skid-steer style QA or an adapter bracket that converts the JD AQ to a skid-steer QA. They also offer lots of attachments and attachment brackets.
)</font>
Is this a weld on only option? or can I use it when I need it and use my standard bucket (and someday the JD snowplow) with the regular JD QA?
   / Other quick hitch implements for JD FEl? #8
I have the ATI adapter on my short list of "things to get" but haven't got the roundtuit yet.
Far as I was able to get from ATI, the ATI setup mounts to your JD loader the same as the JD bucket (i.e. easily removable) - and allows the quick mount or dismount of a skid-steer implement. In other words if you're changing FEL implements - you would have the option of releasing the "front side lock" (leaving the adapter on the loader) to go pick up another skid-steer implement, or unlocking the "rear side" (JD) lock and leaving the adapter on the skid steer implement you're removing - to go mount a JD implement.
Nice flexibility, but you will lose some net lift capacity with this setup. First - the ATI adapter has a certain 'thickness' of it's own - so the skid steer implements are mounted further forward of your pivot point. A small difference but still there. Second - you'll be picking up the weight of the ATI adapter itself (not huge, but still counts). Lastly (and maybe the most impact) from what I've seen skid-steer attachments tend to be very heavily built and typically weigh more than a similarly-sized CUT bucket et al. So - your net material lifting capacity will be reduced some.
POWER CORD W/ REEL, 12G WIRE, VICE (A51244)
POWER CORD W/...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
(11) 8' Treated Posts (A50515)
(11) 8' Treated...
2016 Ram 5500 Chassis Truck, VIN # 3C7WRNAL2GG280521 (A50323)
2016 Ram 5500...
New Harvest T852 8"x52' Transport Auger (A50774)
New Harvest T852...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
