Ordered a snow plow, questions.
   / Ordered a snow plow, questions. #1
Hombre
Goldendale, Wa
Branson 4020R
As stated, I just ordered a new 94 inch hydraulic quick attach snow plow. Branson 4020R tractor. I've been reading quite a bit about "proper" usage while plowing snow. Some say that using the float on the loader places to much down pressure and can cause steering issues. I understand the principle there but there doesn't seem to be much down pressure on "float" to me, I use that setting quite a lot when using the bucket cleaning the barn area from "stuff" and a snow removal "finish" around my shop. I need to add I have an 84 inch snow blower on the rear right now but want the plow for "initial" road clearing of snow. My drive is right at a mile long, mostly downhill from the house with a couple steep spots and is all gravel. I've read where using a chain as a float for the plow is a better option. I'm assuming (I know) that the chain is used to limit the drop angle of the plow to "hold" it above the ground a bit, chain being tight at that point. This doesn't really make sense to me as the weight of the implement will still be on the loader arms. What am I not seeing here? Perhaps when the plow arrives (probably right after all the snow is gone) it will make sense to me. The plow weighs 650 lbs. The snowblower is a bit over 900 and will remain on the tractor also. Kinda rambling I know but I'm still on my first cup of coffee. Oh, snow amount right now is about 2 ft on the ground with more coming but the driveway is good as I've ran the rear blade down a couple times, built up the edges then cut back with the snow blower. The front plow will eliminate changing implements, that blower can be a bear to hook up if all isn't just right.....you're experiences or expertise would be appreciated.
   / Ordered a snow plow, questions. #2
The chain is there so you can pick the plow up and the chain allows the plow to float on the ground (up/down). With out a chain it would have to have a solid mount to be able to pick it up and then it would dig into the driveway or not touch it in a lot of places. Unless you have a perfect level driveway. Hope this helps you.
So what you're saying is that using a chain type plow (hinged attachment point somewhere on plow frame) that the plow "floats" using it's own weight as far as plowing is concerned? The chain being loose allows for following the contour. I had a five yd dump truck with plow that used that system but the plow weighed in the neighborhood of a ton. How do you keep a 500 ish pound plow from riding up as you're pushing the snow. Gonna be a learning experience for sure....Thanks for the reply, I'm sure I'm gonna need help with this. When pushing snow with my International TD 9 crawler, it had a 8 1/2 ft blade that weighed more than the plow on the truck and if I set the blade about 2inches above the snow, (had BIG adjustable feet under the blade)when I saw snow moving out in front about 50ft I knew I had to shove to the side cause' the blade was riding up. ....man you could still tear stuff up with that thing. Stopped using that for snow work.
   / Ordered a snow plow, questions. #4
What about using shoes on the plow, set them the height you want and use the joy stick float?
   / Ordered a snow plow, questions. #5
That would be my preference, if I was going to run a plow blade off my FEL.
That is my plan. Hope it works.....:laughing:
   / Ordered a snow plow, questions. #7
Do you get any frost in you're location? If you don't get much you could have a problem with the shoes ripping up the gravel, maybe not, try it and see, if you do have trouble you might need to weld or bolt a round piece of tubing the length of the cutting edge and use you're float.
   / Ordered a snow plow, questions. #8
Float is all I use except when pulling back to crack any frozen buildup in front of the garage area. I don't use (or need) a chain. I have the plow (an old 7-1/2' Western) mounted to drop arms directly off the tractor frame. At this very moment, I am installing a 1-1/2" x 8" by 7-1/2' rubber strip in front of the steel scraper blade as an experiment to give me better clearing and friendlier contact with my new concrete driveway. The rubber strip is for snow plow use over brick or paver surfaces where a steel scraper blade might dig or scratch the surfaces. Think of it as a squeegee. I will still be using 2 steel mushroom slider pucks to set a blade height. Some of the guys are taking bets on how long the rubber will last. The mounting holes will be slotted so I can drop the rubber strip as it wears. If it lasts just 3 seasons I will be delighted.
   / Ordered a snow plow, questions. #9
Force vectoring. If you place the loader boom in float, your single push point is the loader boom mounts. This point is about five feet off the ground. The loader boom will be fully pushed back/lowered when attempting to push snow. When you keep your boom lift cylinders in neutral or static position, your push point is now the bucket hinge pin. Low enough to not upset the force of the tractor which is higher. A snow plow doesn't need to be held down against the snow because of the angle of the cutting edge. Once the moldboard gets full of snow, there is a decent amount of force down on the cutting edge. It's the reason that so many struggle with the first wet snow of the year on in frozen ground. The plow lift chain is your best bet.
   / Ordered a snow plow, questions. #10
Bingo!
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A51039)
John Deere 1110...
2012 FORD F-650 (A50854)
2012 FORD F-650...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2009 FREIGHTLINER CASCADIA SLEEPER (A51222)
2009 FREIGHTLINER...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
