ORB to NPT
   / ORB to NPT #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
I thought I recalled reading that an ORB/SAE male could thread and seal on NPT female as long as it was "hydraulic" style NPT threads.
Is this so?
   / ORB to NPT #2
No npt is tapered orb is straight thread.
   / ORB to NPT #3
There's no such thing as "hydraulic" style NPT. NPT is NPT and nothing else, it's a tapered pipe thread. NPT stands for "national pipe taper.
   / ORB to NPT #4
Simple answer is NO. What are you trying to accomplish....adapters are cheap.
Most of the NPT and SAE threads are different pitch.
Only ones that look on paper like they would be close are...
1/4" NPT which has 18 TPI, Male thread OD is .54 Female ID is .49....matched with
-06 SAE which is also 18 TPI, male thread OD .56 Female ID is .51
And
1/2 NPT.....14 TPI......OD 0.84......ID 0.77
-10 SAE.....14 TPI .....OD 0.88.....ID 0.81
Everything else is vastly different in size and thread pitch.
Cant say with 100% certainty that it wouldnt seal if you tightened it enough, because I have always just used the correct fittings / adapters.
   / ORB to NPT #5
Shaneard, actually there "sorta" IS a "hydraulic style" pipe thread - but they don't call it that, it's called NPTF. the "F" stands for Fuel, the threads are supposedly a bit different for an easier seal. They are compatible with normal NPT threads but mixing the two negates the "F" advantage... Steve
   / ORB to NPT
It sounds like I was using the wrong term. It was my understanding the threads were compatible. Thanks for the clarification.
   / ORB to NPT #7
"NPT Vs. NPTF Taper Pipe Threads
The two most common taper pipe threads used in the United States are NPT and NPTF. Applications range from electrical conduits and hand railings to high-pressure pipe lines that carry gas or caustic fluids. NPT threads are for mechanical or low-pressure air or fluid applications and require the use of sealing compounds like Teflon tape, to provide the seal. When the application is more critical, and the sealing compound may fail due to high heat or pressure, NPTF Dryseal threads are used. This mechanical seal is produced by the mating and slight crushing of the threads when a wrench is applied to tighten the fittings.
Visually, both threads appear to be identical. Both have a ¾” taper over one foot of length. Both have the same pitch diameter at the top of the hole of internal threads or end of the pipe on external threads, and both have the same thread lengths or depths. However, there is a subtle difference in the thread form that differentiates the two. The major and minor diameters of both threads differ slightly. With NPT threads, after a wrench is applied, slight spaces at the major and minor diameters may exist that would allow the assembly to leak and therefore a sealing compound is used to fill any gaps. On the other hand, NPTF threads are designed to ensure that sufficient crushing of the entire thread form will take place to produce a mechanical seal.
How does the difference in thread forms effect the tooling used to produce NPT and NPTF threads? Taps are available for both NPT and NPTF threads having the appropriate form to produce each type of thread. Since NPT threaded parts require sealing compounds, it is acceptable to use an NPTF tap for NPT applications. However, NPT taps cannot be used for NPTF applications, as it will likely produce a thread that will leak. The same is true of external threads. In most cases the tap drill is the same for both forms.
The most significant difference in the two threads is the inspection required. Since sealing compounds will be used for NPT threads, only a single plug with a step, known as an L1 plug (internal thread) or a single thin L1 ring (external) are required to check size. However, since the taper and the position of major and minor diameters are so critical to the sealing of NPTF threads, the additional threads in the assembly known as L2 and L3, and the major and minor diameters are inspected with either special plug or ring gages."
I copied that from the internet, don't mix the two, you'll be better off.
   / ORB to NPT
I was on the surplus center website and wanted to have a homeowner type setup of adapters and fittings. Thats what I am trying to do.
   / ORB to NPT
The copy and pasted text is ringing a bell. It's some of the NPTF that can be assembled dry as they rely on a mechanical seal.
Who knows how I got the ORB/SAE mixed into this. But once again TBN was here to correct the record.
   / ORB to NPT #10
ORB and JIC are the same pitch and diameter. In a pinch you can use a male JIC fitting with an 'O' ring on the shoulder to fit into an ORB port. You might have to cut off the taper if it's too deep.................Mike
2014 FORD F-150 (A45046)
2014 FORD F-150...
1997 Ford LT9000 T/A Day Cab Truck Tractor (A44571)
1997 Ford LT9000...
2016 Chevrolet Silverado Pickup Truck, VIN # 1GC2CUEG6GZ333208 (A44391)
2016 Chevrolet...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A42744)
2019 Harley...
Wacker Tamper (A42021)
2021 Ford F-150 XL (A44501)
2021 Ford F-150 XL...
