BackRoad
Veteran Member
3rd function uses flatface Male and Female Quick Connectors (QCs) with 1/2" nominal port size (-08) O-Ring Boss (ORB) seals.
On the tractor side, the Female QC was dripping sufficiently at the ORB fitting to warrant investigation.
1. Attempted to tighten the ORB fitting: No joy
2. No visually apparent defects with either part of the O-Ring seat.
3. Replaced the O-ring with a new one from NAPA: No joy
4. Tried some hydraulic sealant on the threads, along with the new O-Ring: No joy
5. Swapped the Male and Female QCs to see if problem followed the QC or the O-ring: They both started leaking!
6. Ordered new O-Rings from Discount Hydraulics (thinking NAPA O-ring might have not been 100% sized properly). Replaced both the male and female O-Rings and returned them to the original configuration: Now back to just the Female leaking, not as bad, but still not dry.
So...short of buying a replacement flatface Female QC - and - the O-ring base connector, are there any alternative suggestions or hacks for sealing a leaking ORB connection?
Do they make "super" O-Rings that might be slightly "thicker" than standard (-08) O-Rings?
Is there a thread sealant that works for use with ORB straight threads? (Anyone have success with a careful application of Teflon tape?)
Can an ORB connection be over-tightened or over torqued?
Thanks for any suggestions!
