So I picked up the tractor a couple of weeks back, it didn't have a battery in it so I couldn't even try to start it. Got a battery about a week ago - and the thing turns over like a champ but doesn't even give a hint of starting. The previous owner told me the guy he got it from had said it was "hard starting" and had obviously been playing around with fuel because there was a jury rigged hose coming from the fuel pump just hanging there. I'm trying to take a one-step-at-a-time approach to getting this thing back up and running. Putting a battery in it showed me it turns over just fine. The compression tester was delivered by UPS today - so after work I did a compression test on it - and both cylinders top out at about 120 psi. So that seems pretty good.
I did play around some with the alleged fuel issue - and noticed that the fuel pump didn't seem to want to suck any fuel out of a gas can from the jury rigged hose - when I cranked it over. A fuel pump is only like $21 so I got one from Amazon a few days ago and hope to maybe get that installed in the next few days. The fuel lines look pretty rough as well - and I've got some fuel line
coming in the next day or two so I'm just going to run new line back to the tank - and clean the tank out as well - I could see crud floating around in it.
I also scored a halfway decent 46" deck last weekend - I've just got to pickup the correct belts for the deck itself and the mule drive. The idler pulley on the deck appears to be shot too - so I think I need to rebuild that. I'm also going to have to put tires on it - the ones it came with are seriously cracked and one of the fronts has already leaked down to completely flat.
There's a few other odds and ends I've had to deal with (the rockshaft was missing when I got it) - but I hope to get this thing back to working in the next few weeks.
