Options for 3 pt hitch shredder/chipper?
/ Options for 3 pt hitch shredder/chipper? #1
tillboy2001
I see a DR Chipper/Shredder as an option but it's $3,000 for the chipper/shredder combo or $1,889 for the chipper only option. Mounts on the 3 Pt Hitch. Looks to be high quality.
Any other nice quality options out there for a chipper/shredder combo?
/ Options for 3 pt hitch shredder/chipper? #4
How heavy duty are you planning to go on this?
Valby makes some excellent chippers (6" capacity). These are commercial duty units, and are available with optional hydraulic power feed. I've used my neighbors quite a bit, and really like it. I don't know if they have shredder models or not... don't have much use for a shredder myself, so I've never looked into it.
John Mc
/ Options for 3 pt hitch shredder/chipper? #5
I just checked them out. It looks rather lightweight in the picture, but no less so than anything else in it's price range. It all depends on what you want it for.
I've been looking at chippers myself for several years; but as much as I'd use it I really need a commercial grade unit. Instead I pile slash and brush all year, then burn it in the spring. I use about the same amount of diesel, for fire starting instead of running my tractor; but save the price of a chipper.
/ Options for 3 pt hitch shredder/chipper? #6
I just bought a Jinma 6" chipper from Homier about a week ago:
Homier Farm Pro Chipper
They private label it under their own Farm Pro brand but it's the same as a Jinma. It's a decent quality unit, given the price. It has some shortcomings, most notably the driveshaft mechanisim for the feed roller, which are easy to fix if you are at all mechanically inclined. There are several websites covering how to service the unit and do retrofits to handle the problem with the feed roller.
At $1599 (plus $130 shipping) it is a steal in my opinion. I have about 6 or 8 hours of chipping time on it so far, behind my Kubota B2910. The B2910 has adequate power for up to a 4" log when running at PTO speed - anything over that and I have to feather the feed or otherwise I'll stall the tractor.
And although they call it a chipper/shredder it's really only a chipper. /forums/images/graemlins/grin.gif
/ Options for 3 pt hitch shredder/chipper? #7
If you only need to use one once in a while, Home Depot has a nice unit they rent out. It is less then $200 for a whole day (I think it was around $160 but don't remember). The Home Depot here has a Vermeer unit with its own power source and it throws the chips away from the unit to help spread them if you are just mulching them where you cut.
Looking for something to chip maybe 4-5 inch wood and also a shredder. I've found more sites on the web and have a few catalogs coming to check out. We'd like to have one to keep, not rent. These things are expensive...I know that!
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Unverferth 632 (A64119)
Unverferth 632...
1051 (A63291)
1051 (A63291)
MF GC2300 fel replaced
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
