Optimal idle speed for operating a 4550 under light load
   / Optimal idle speed for operating a 4550 under light load #1
gardner175
Stevensville, Mi
Mahindra 4550
I have a question on optimal idle speed for operating a 4550 under light load. I have a tier four 4550 and am asking because of my very limited understanding of the diesel, hydraulics, and catalytic converter operation.
There is a decal on the tractor, and statements in my owner manual, that state: “Do not exceed ½ throttle for the first 5 minutes of operation”. There is also a note in my owners manual that states: In cold weather, idle and warm up for 5 minutes at approximately 2000 rpm before loading”.
My tractor RPM meter goes from 0 to 30 (0 to 3000 RPM). So I would calculate that half throttle would be 1500 RPM.
Now to further confuse things the owners manual says: “Do not apply load on the tractor at low engine speeds. Always apply heavy loads at full throttle RPM of engine”, however it also talks about the PTO 540 Mark: “This mark is located in the RPM meter at 2058 RPM of engine. It indicates the Engine RPM at which the PTO shaft will rotate at 540 RPM”.
I would have thought that operating PTO driven equipment would qualify as a “load”, however the engine RPMs for PTO speed seem to be less than 1 revolution per second more than the cold weather warm up idle speed. I am so confused!!!!!!!
So, is it damaging to the engine, hydraulics, and/or catalytic converter if I idle the tractor at about 1500 RPMs for an extended period of time while holding a raised 800 lbs load in the FEL?
I am asking this because I frequently need to use the tractor as a wheelbarrow to move loads of mulch to the garden where I need to hand distribute it around plants with the tractor idling in neutral. I have found that when I idol at PTO speed while the tractor is in neutral I can't get it in gear without grinding, even after I have depressed the clutch for several minutes. I need to slow the RPMs down for several minutes before I can put it in gear from neutral. If however I let the tractor idol at 1500 rpm I can quickly shift into gear from neutral and move to next spot where I will be hand distributing mulch.
Sorry for all the detail minutia, but I am way over my head on this. I don't want to damage the tractor, and am looking for best practices ideas.
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
2015 Chrysler 200 (A50324)
2015 Chrysler 200...
2022 Doolittle 7712 - SS Trailer (A50514)
2022 Doolittle...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
3 pt Post Hole Digger (A50515)
3 pt Post Hole...
