Optima battery only solution?
   / Optima battery only solution? #1
tillboy2001
Is installing a battery like the sealed optima the only solution to the acid dripping out on my 4120? A few times I've seen it bad enough that it foams up below where the battery is and it's eaten off some of the paint already. I will mention this to my mechanic (dealer), but if they're going to reinstall the same battery and won't pay for an optima, then I figure we may as well do it ourselves. Is the optima the only solution?
   / Optima battery only solution? #2
You could do something like this:
battery
See John Hardy's explanation:
johnday
I just called my mechanic a few minutes ago and he mentioned checking to see if there was a drain tube in place and if there wasn't, he'd see to it there was. I'll have to wait to see what happens when he comes out to fix the fuel gauge (which is not working). He'll check the battery issue when he comes for the gauge problem.
   / Optima battery only solution? #4
My 4310 has been in twice for leaking batteries. The first time it took out the transmission cooler (it's a hydro) along with corroding most of the metal in front of the cooler. It came back looking good as new with the "improved" Deere LVA11726 battery.
Two months later (a couple of weeks ago) the "improved" battery was leaking but hadn't got the cooler yet. I called the dealer and squawked about a getting a sealed battery (like an Optima /forums/images/graemlins/smile.gif ) and it came back (looking as good as new AGAIN) with a sealed Interstate battery at Deere's cost.
The dealer did mention about having to get the sealed battery replacement approved by the Deere field rep.
   / Optima battery only solution? #5
If they atart to seep around the posts there's not much you can do. Delco side posts can do the same thing...
   / Optima battery only solution? #6
At $100 for an Optima, there is hardly any other solution that makes sense to me. Even if the repairs are done in warranty, it still costs more in time to have a battery that can wipe out the radiators and frame. Optimas are 'bombproof' Every other 'solution' just tries to avert the problem. A tube leaking the fumes out the bottem isn't as real fix, somethings gonna get that nasty stuff. Automotive batteries aren't up to all the jolting that a tractor takes.
In addition to the protection from leakage, the Oprima is made to handle deep discharge situations better. With paltry alternators, and lots of places to stick lights, that is a huge asset.
Of course, your mileage may vary.
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2019 FORD F-150 (A52472)
2019 FORD F-150...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
