Optima Batteries
   / Optima Batteries #1
lilranch2001
Super Member
Bobcat CT 235
I was in Advance Auto yesterday and was looking at the Optima batteries.
The guy behind the counter was bragging them up, and then made the statement to the effect "as long as you run the vehicle all the time"
Well I was all about the gel batteries until that, there are times in the spring or fall I do not run the tractor for a few weeks at a time.
Any thoughts?
   / Optima Batteries #2
I run 3 Optimas, the first two are older, before the company was bought out- the last one newer.
One, mounted in an SUV that was not driven all summer, eventually would not start the vehicle and needed a full charge- but I take the blame for that.
No matter what type of battery, if you plan to let it set, I would use a maintainer- either 120v or solar. Cost < $50 and they will do their job for years.
   / Optima Batteries #3
I have an Optima Red Top in my tractor and it has been flawless since I installed it about six years ago. My electrical system is perfect and has no drain on the battery so that I've left the tractor for over a month and it still fires right off. The Optima is NOT a gel battery. It's an SLA (Sealed Lead-Acid). I've had such good luck with mine that I'll happily replace it with another one if it ever fails.
   / Optima Batteries #4
I had an optima gel battery in my RTV and it went dead overnight and it was about 4 years old. The RTV runs just about every day so it was not a issue of setting too long. It developed a short in the cells according to the NAPA guy who tested it. I asked about replacing it with another Optima but he didnt keep them in stock, said he didnt sell many because of the price. He said a regular lead acid battery will work fine as long as you arent rock climbing and turning over etc. Since I dont anything like that, I just replaced it with a regular battery.
When I owned a Cessna, the lead acid battery in it had special caps that prevented acid spills. I suppose one could by some of those for a lead acid battery and be equivalent to the gel cells as far as acid spills. They are also supposedly better at absorbing shock loads but my RTV is just used on my pasture and inter-farm roads so it got little to no shocks but still failed.
Just my 2 cents worth, but I wont buy another one. Neither will I pay Sears $170 for a Diehard with 3 year warranty when I can buy other brands for half that with 4 years or more warranty. I just came back from replacing one in wifes car that sat for about 4 months and the Walmart battery went bad. It was 3 1/2 years old and replacement cost was $48 on an $89 battery with 3 years free replacement. Some high cost stuff just isnt worth the extra money especially if you can buy something for much less with same warranty on it.
Next replacement will be on my 2007 Chevy truck with factory battery in it that is showing signs of weak starting so I expect it to go out soon. I rarely get more than 4 years from any battery in the southern heat they go bad pretty quickly.
   / Optima Batteries #5
My Optima battery is a D31M about four years old. It is in my truck, the longest it sits is for a few days. The battery still works as well as it did on day one.
   / Optima Batteries #6
I have a yellow top Optima that is used for several things. The main use is for the trolling motor on the boat. The other uses are for emergency power using an inverter for the pellet stove during outages. It holds a charge well and sometimes sits for months with no ill affects on the battery
It is a good (expensive) battery but I do not think it is any better than a regular lead acid battery. The Optima is sealed and does not emit fumes which is good when I bring it in the house for outage use. If I did not need it for emergency power I would go with a regular lead acid battery.
   / Optima Batteries #7
I've had the worst luck with optima batteries.
After a lot of research I found batteries made by this company to be superior to anything I've ever used.
EAST PENN manufacturing co., inc.: Lead-Acid Batteries; Battery Manufacturers; Thousands of Different Types of Batteries, Cable & Wire Product
Call then up as they make batteries for a lot of companies and just put their name on it. They will tell you what you need and who sells it under what name near you.
Example; I called on a Mecedes battery that was $300.00 and they make them gave me the same battery they make for NAPA for $100.00.
   / Optima Batteries #8
I have 21 red and yellow optima batteries in various things. Had the first one actually go bad recently in a large backhoe with 8 years service. Have some over 9 years old working just fine.
Lots of threads on forums about how the quality took a dive after they moved production to Mexico. I don't have any less than 3 years old. In spite of my great experience I am not sure I would buy another due to the recent bad reviews on the internet.
Tried a high dollar Oydessey battery and bought the high dollar matching charger because of all the positive hype, virgin lead, etc and was not impressed.
   / Optima Batteries #9
I was going to buy an optima but after doing a little research I found that Diehard makes the same style of battery (I think the Platinum) but instead of being 6 round cylinders stuck together (very inefficient use of space) they just sandwich the mats so it uses all the space of the rectangle shape.
   / Optima Batteries #10
I use absorbed glass mat (AGM) batteries (not gel cells) in all of my equipment.
I use Odyssey brand.
Frontier FM2015 (A50120)
Frontier FM2015...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
