opinions on safety upgrades?
   / opinions on safety upgrades? #1
Ginormous
Dayton, Ohio
Yanmar YM2210
My gray market Yanmar didn't come with the safety upgrades that the UTDA dealers are putting on them. What do you all think about these different options? Critical? Nice to have? Worthless?
ROPS?
PTO safety shield?
overrunning PTO clutch?
clutch safety switch? (I don't even know what this is!)
   / opinions on safety upgrades? #2
ROPS?
PTO safety shield?
I purchased ROPS b-4 they came up with UTDA (for my peace of mind). I don't have PTO shield. I built 1 but, didn't install it. You will need over run clutch if you bush hog. Mine came with clutch safety switch. Keeps you from starting the tractor without clutch being pressed incase, tractor is in gear when you try to start
   / opinions on safety upgrades? #3
I added a ROPS to my 336d tractor and on the hills I use it on I am glad I have it. One time I hit a depression in the weeds and the tractor would have rolled over but the roll bar fell against a tree and kept it from going over.
I also use my seat belt. I think the cover on the PTO is important also, anything loose can be caught there.
   / opinions on safety upgrades? #4
On my 276D, I have a rops, & overunning clutch. No PTO shield. I disabled the clutch safety switch this past winter.
   / opinions on safety upgrades? #5
Good on you for even asking the question. I think that like a lot of things safety depends largely on the operator. Some people enjoy paying attention to every little detail while others enjoy a more meditative state while working. If in doubt as to which group you belong to, it might be a real eye-opener to simply ask your wife..... :)
In my opinion, all of those safety devices you mention are of a type that provide good protection against poor judgement or lapses in attention and little protection at all against an unusual or unavoidable event. So in rating the value of safety devices I'd put operator first, experience second, and devices a distant third.
rScotty
   / opinions on safety upgrades? #6
I am speaking for myself only, and am not trying to tell you what to do. These are only my opinions, and worth exactly what you are paying for them. :D
As a rule, I dislike "safety" features on many products. I don't like the automatic sensor in my car that tells me when it's dark outside, and turns on the headlights for me. My little riding lawnmower shuts off if I ever hit a bumpy spot, or lean over to see if I'm going to clear an obstacle with the mower deck. "No-spill" CARB portable fuel cans spill many times the amount of fuel out for me than the "evil" ones with just a spout. I bought a new heating pad for a sports injury that shuts off every two hours-just as I was finally getting comfortable each time I fell asleep during the night.
However, I always wear a seatbelt when I drive, a helmet and excellent gear when I ride my motorcycles, and hearing protection whenever I operate the tractors. I think anyone who doesn't is making very poor choices. BUY AN OVERRUNNING CLUTCH! I thought they were a stupid waste of money on a "safety" feature that would make the cutter more difficult to use in hooking up. They aren't, at least with a mower.
Even ignoring the safety aspect, the usability improvement is worth every penny. Without the overrunning clutch, shifting between gears requires a lengthy stop (since the mower will drive the tractor at least 6 feet further than you want it to, while applying the brakes), placing the PTO into neutral. Back up, select your forward gear. Shift into gear on the PTO, then face a period of getting the cutter up to speed again before it will cut well. If you're trying to back under trees or into a corner, there's a significant amount of uncut material while the cutting blades get up to speed.
With the clutch, the mower stays spinning, freewheeling. Clutch in, select gear, back up, select new gear, lower cutter, drive away happily. The blades stay at speed, and there is no loss of effectiveness. Plus it's vastly quicker. Then, additionally, you don't have to mower powering the tractor forward while you hold the clutch in and frantically mash the brakes, trying to avoid hitting the fence/dog/house/new fruit tree/unseen metal pipe etc. And that is only better, safer and preferable.
Buy an overrunning clutch. It's worth twice what they charge. And I HATE spending money on add-ons.
I don't have a single machine with ROPS. They are probably smart to have. It's also probably not smart for me to do some of the other things I do, whether working around farm equipment on this little toy farm or hitting a big jump on my motorcycle. Instant death or maiming is possible every time I do either of those things. Flying small airplanes is as bad. I enjoy all of it. I've never been close to rolling any of my tractors, or flipping over backward.
A ROPS would make it impossible to do some of the tasks I need my machines for, like disking, mowing, and/or tilling around orchard trees, even if it folded. My property is also virtually table-flat. I recognize the dangers not having a protective system brings, and trade that against the usefulness of what I need the machine to do. If I had a different environment or job description for my tractors, I would pick one up. Having said that, I AM going to purchase the ROPS for my little Kubota B6000. I envision selling it in the near future, and the system is only $148 through Kubota. The next owner can then do whatever he wants, and I have a clear conscience.
I didn't like PTO shields when I only had one operable tractor and would run 4 or 5 PTO different powered implements in a weekend. They made it harder for me to hook things up quickly, and, actually, tougher to hook up at all. I took mine off. Now that I don't hook up and unhook so many things all in a weekend, I can compromise on how I approach things. The PTO shield does keep things from being caught in the U-joint and output shaft. Getting wrapped up in the PTO shaft or drive would be a maiming that one would probably prefer to die in, rather than survive.
The effortless power any of these machines have (Even the tiny B6000) would crush any of my bones and wrap me around the shaft with only horrific results, without causing too much of a fuss to the tractor. I haven't paid money for any, but I have only taken one of mine off, out of three.
I don't have an opinion about the clutch safety switch. They aren't enough of a nuisance for me to remove, and I don't see them as being an improvement to mine or others' safety, so I haven't put any on.
One thing unmentioned: I would build or buy (building would be super cheap and simple) a set of chain guards for the cutter if it doesn't have them already. I had a scary experience a couple weeks ago with mine. When I used to pitch playing baseball I could throw 94 mph on the radar gun. I ran over an 8 inch chain link fence splicing connector and the cutter hurled that thing seemingly twice as fast as my pitches would go at their fastest. I don't know where that steel tube of doom came from, and, actually, I still don't know where it went. (It sailed over into a vacant lot, thankfully.)
But there is no doubt in my mind whatsoever that it would instantly kill someone were it to hit their head or neck, and would easily have the ability to cause commotio cordis (stopping of the heart by blunt impact under certain conditions). A chain guard won't stop it entirely, but at least may suppress the fling from chest and head height to knees and below. I'm going to build something for mine.
Especially with kids, get them inside and away from the windows when you're running that mower. Same with any animals you like. I've only ever seen that one object get hurled like that, and it may never happen again, but once was enough. It would have been as lethal as a rifle bullet had it hit someone in the head.
I agree with rScotty about the ranking of safety features. Operator experience, intuition, attentiveness and attitude trump all the rest. Usually safety equipment is a crutch. Check out these guys: transmission tower workers. Humor me and watch at least 2 1/2 minutes.
What some consider a normal day of work would petrify others. You're doing all the right things and asking all the right questions. It's good to have you here!
284 -- Thanks for the long reply. My feet are all sweaty now because of watching that video... thanks. :shocked: How would you build the mower chain guard? I agree, that shoulds like a very good idea. I have an overrunning clutch on order because I thought that was worth the money -- thanks for confirming that. I tend to work very carefully -- I'm a woodworker with all my fingers :) -- but I'm still debating the ROPS, especially since everyone agrees it's a pain at times. Half of our land is flat and half is sloped. I would feel very silly if I got killed by my tractor rolling over me, so probably I will get one.
   / opinions on safety upgrades? #8
Good idea to get all that stuff and if possible get the roll bar that folds they are handy!
   / opinions on safety upgrades? #9
I just bought a ROPS for my 2020D and installed in an hour or so. Expensive yes....but I think its a necessity.
I have a Sears 12 hp tractor and a hill I needed it to climb. I installed dual wheels for stability and added weights and chains to the outers. One day, on another part of the property, in first gear and half throttle I entered in a small depression and slight rise. Before I new it the front of the tractor was straight up. Luckily the tractor was small enough that I jumped off the seat and backwards - My left hand caught the hood of the tractor to protect me as it was coming down on me...my hand looked like a catchers mitt for a week. Did I mention I was in first gear and half throttle in a 12 hp gas engine tractor???? In any event....It happend so fast and I never thought that anything like this could have happened in the area I was.
Subsequesntly I welded on a weight bar to counter the heavy rear weights of the tractor.
Point being is....ya never know what you might end up doing with your tractor
   / opinions on safety upgrades? #10
Rops can be a pain at times, but to be honest unless all your land is flat, and you never use a loader I would always have some form of ROPS fitted - it will save your life if the tractor tips over!
If you have a lot of trees, look at fitting a folding ROPS which can be lowered to work around the trees - but always remember to put it back up afterwards.
Also the clutch safety switch... I always thought these were a waste of time (although all our tractors have them fitted as standard) - that is until a friend of mine had trouble starting his fordson major one morning. After getting on and off a few times to tap various parts of the engine, he turned the tractor over while stood next to it, forgetting that he had left it in gear! It fired immediately and ran over his foot, before crashing into the barn wall and stalling again - it then stayed there for 4 weeks, until his foot was out of plaster :confused2:
2020 KUBOTA RTV...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2024 Deere 317G (A50123)
2024 Deere 317G...
2023 G Bar K Goose Neck Flat Bed (A53473)
2023 G Bar K Goose...
