opinions on john deere 4115 tractors
   / opinions on john deere 4115 tractors #1
rober
Gravely 5665
anyone have one? pros/cons? there's one nearby with 780 hours, good rubber, & not a beater & it's plumbed for a loader
   / opinions on john deere 4115 tractors #3
I guess this tractor never found a market...too small for some work, too big to be a lawn tractor...shame.
The Deere/Yanmar machines are great...easy to start (in cold weather), sips fuel. It might be difficult to find a 410 loader, if you want to add one.
Parts should still be available...definitely the mechanical parts.
If it's a good price, and you have need for a tractor this size, why not?
   / opinions on john deere 4115 tractors #4
I have the 4110, is little brother, the 4115 was a few inches longer and had a direct injected engine with about 4 more horses-otherwise the same machine. Like Roy wrote the 410 loader would be hard to find, the 200cx was available to fit too at the end of the production run. These are Yanmar built machines, and very solid.
I have 1/2 acre. i'm currently running an Ingersoll 4016 with 3 pt & hydraulic PTO. I need a mower & would like to be able to plow, disc, & till. I have Brinley plow, disc, & harrow. would these work with this rig? what class equipment does the 4115 use? 780 hours is fairly low. what might this be worth? he's asking $7200.00 another alternative would be to use the Ingersoll for garden work & buy a good mower.
7
   / opinions on john deere 4115 tractors #6
I suspect the 4115 would be a little light for ground engaging implements...a PTO driven tiller would work (if sized correctly for the tractor), not sure about a plow.
The asking price doesn't sound out of line.
the Ingersoll is smaller & 16 H.P. & will pull that Brinley ( 10" ) plow. i'm not sure how they are rated but I think these smaller implements are class 0? the disc or harrow should not be an issue. i'm still looking around. i'm not 100% sure what I want. there's also a farm pro available. I know nothing about those. I have a clean IH model 284 I need to sell. I sold a piece of land & no longer need it. too bad it won't work here. it's a nice tractor.
2012 FREIGHTLINER CORONADO 122 SD (A45333)
2012 FREIGHTLINER...
2022 Honda Rubicon TRX520FA6 4x4 ATV (A42744)
2022 Honda Rubicon...
J&J MANUFACTURING UTILITY TRAILER (A45333)
J&J MANUFACTURING...
2012 GALYEAN 130BBL VACUUM TRAILER (A45046)
2012 GALYEAN...
Pallet of irrigation Hoses (A44502)
Pallet of...
2009 PETERBILT 367 TWIN PUMP CEMENT TRUCK (A45333)
2009 PETERBILT 367...
