CampyVA
Hi All,
Considering going to look at a low hour used John Deere 3203, but I'm concerned about it's low loader lift capacities (John Deere 300). They seem to be much lower than most tractors of this size, although the max lift height is very high by comparison, so that may explain it. I intend to use the loader to spread gravel and lift fallen trees and branches on our 19 acre farm. Am I overly concerned about the specs? See below.
Loader type: John Deere 300
Height (to pin): 112.8 inches [286 cm]
Clearance, dumped bucket: 68 inches [172 cm]
Dump reach: 33 inches [83 cm]
Dump angle: 40.5
Reach at ground: 53.7 inches [136 cm]
Rollback at ground: 21
Rollback, raised: 101
Breakout force (at pin): 1,728 lbs [783 kg]
Breakout force (at 500mm): 1,229 lbs [557 kg]
Breakout force (bucket): 1,115 lbs [505 kg]
Lift to full height (at pin): 740 lbs [335 kg]
Lift to full height (at 500mm): 547 lbs [248 kg]
Lift to 1.5m (at pin): 951 lbs [431 kg]
Lift to 1.5m (at 500mm): 740 lbs [335 kg]
Attachment style: hooks and lock pins
Raise time to height: 3.2 s
Bucket dump time: 2.71 s
Lowering time: 1.63 s
Rollback time: 1.38 s
Dump angle: 40.5
