Opinions Needed
   / Opinions Needed #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST, Kubota ZD1021, Kawsaki Mule 4010 trans 4x4
Opinions ...on towing a 5000# trailer (2 axles with brakes) with a 2006 Dodge Dakota v6 engine 230 HP/210 TQ 6010 GVWR
   / Opinions Needed #2
Is 5,000# lbs the weight rating of the trailer, or the actual loaded weight? If it's the actual loaded weight, does it include the weight of the trailer, or just the item(s) loaded on it?
   / Opinions Needed
rating plate on the trailer ....GVWR 5000#
   / Opinions Needed #4
GVWR is the total weight of the trailer and the load it is carrying. Since yours is 5,000 lbs and since we don't know the size and weight of the trailer, I would estimate the trailer weighs 1500-2000lbs. So figure 3,000lbs of allowable load. Your dodge should pull that weight no problem.
   / Opinions Needed
This is a small travel trailer.It's not a car hauler. So, that rating ( I assume )would be the load
   / Opinions Needed #6
You might be surprised at how heavy travel trailers get once you add food, water, clothes, and other 'household' items. I'd advise weighing it after you get all your stuff in it. It may be heavier than you expect!
   / Opinions Needed
Best I remember, (looking in the book for the trailer ) That 5000# GVWR rating was total/max weight for the trailer loaded
   / Opinions Needed #8
I have an 07 with the v8 and I pull my enclosed trailer with the bike in it and it's about 2500 pulls it fine but the mileage is sure terrible!!! :( I wouldn't pull that kind of weight unless the trailer had brakes! !
   / Opinions Needed #9
That would be the maximum weight the trailer is intended to haul. It could be loaded well beyond that number, though. The only way to know if you're within the weight limit is to load your trailer with the stuff that you would take on a trip, and then go to a truck scale and weigh it.
   / Opinions Needed #10
Yep, I learned that lesson when we were RVers. Our fifth-wheel came with two 3,500# axles and after I ruined a couple of tires enroute to Alaska, I discovered that we were running 7,300# on a suspension system designed for a maximum of 7,000#.
2020 FORD F-250 SUPER DUTY (A52472)
2020 FORD F-250...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
2013 Cadillac SRX SUV (A50324)
2013 Cadillac SRX...
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
