Bigg Country
Hello ALL
I just bought a New M7040 with LA1153 Loader and had my heart set on buying a Bushhog model 326 Rotary Cutter. All the brochure specs showed 3308lb 3pt lift capacity. I got the tractor and the owner manual states max weight for rotary cutter is 1200lbs. PTO requirement for cutter is 60HP minimum and tractor has 65 so no problem there. The cutter approximate weight is 1400-1500LBS I don't think the tractor will have any problem handling this cutter as long as I get the ballast right. Like to here from M7040 owners and their opinions.
I have 90 acres 1/3 is hay field and pasture the rest is hilly with 2 year old clear cut and densely wooded would like keep sampling cut in clear cut and clear some of the wooded area and cut paths. So yes I want the heaviest mower my tractor can handle. The 326 has a 4" cutting capacity.
