Operating Temperatures Help Please
   / Operating Temperatures Help Please #1
piperc744
Colorado
FarmPro 2425
Hey guys,
I have a 2005 FarmPro 2425 3 cylinder Diesel tractor.
I have noticed since I got the thing about 6 months ago, that the temperature gauge reads very high almost all the time.
My question is... is this normal? what operating temperature do you guys find appropriate?
The meter reads: 100, 80, 40. and the arm works its way up to about 90 after like 15 mins or so, when its warmed up good. then it will go up to 100 after another 20 mins now.
I have sealed up all coolant leaks that i know of.... I feel maybe the fan is not working properly, although it is running....
   / Operating Temperatures Help Please #2
Hey guys,
What does your owners's manual say is the normal temperature? Does it have any info about the thermostat? Is it a 180°F thermostat? Are the temps you're quotting °C? if so then 100°C is 212°F. Whether that's high depends on whether you are working the snot out of it or just driving it around. What's the rating on the pressure cap for the cooling system? While 212°F may seem high if you have a 10 psi pressure cap it's not a concern because our are not boiling the coolant which will reduce is cooling effectiveness.
Generally speaking, the middle of the temperature range is "normal" (moderate work, not pulling a 5 bottom through heavy clay) and there is generally a range between the middle and a temperature "red line" where you are definitely over temping.
Without more info from you I can't be of anymore help.
Hey Jerry,
thanks for replying. well i do not have a manual for this tractor, as the previous owner threw it away since it was in chinese.... i did however find out through these forums that my farmpro is equivalent to the jinma 200 series, and someone linked me that manual... but the only problem is, there is nothing that i can find in there about operating temperatures.
ive concluded that it is absolutely running too hot. it seems to reach max temp on the gauge sooner and sooner now.... and although there are no leaks, i still have to put a half gallon of coolant in every couple days. the cap has a hose that runs down the side of the radiator. that hose leads down to the axle area and is dumping coolant there which explains the refills. that also tells me that the radiator is getting way to hot way to fast.
is there a special coolant i need to be using, im using general stuff from the part store, same stuff we use in my diesel truck...
what else could be causing this? i ran it for about 30 mins today before having to stop to let her cool off, im scared ill overheat it. when i first start it, the gauge slowly works its way to the right at the bottom 40 mark, then it slowly raises over the next 15 mins to about 70-80 and then from there over the next 20 mins it maxes out to the 100 mark....
   / Operating Temperatures Help Please #4
I'm not a mechanic but either the cooling system isn't functioning or there is a cause for excess heat that is overwhelming the cooling system.
I'd start by checking the oil and looking at it. Check transmission fluid and look at it. That's about as much as I can help with in regard to excess heat generation.
As far as the cooling system goes, check for leaks, obviously. Make sure the screen in front of the radiator (if equipped) is clean of debris. Make sure the outside of the radiator is clean of debris. Make sure the fan is turning and make sure the fan is on right and blowing the right direction (I've heard of them being reinstalled backwards...if that's even possible). Then, I guess you'd need to check the water pump. Not sure how to do that without pulling it off except to crank the tractor and while still cold remove the radiator cap and look in and see if the fluid appears to be flowing.
That's about all I know to do.
wow thanks, will try all of that, and i will take any advice any one has, so feel free!
   / Operating Temperatures Help Please #6
Did you burp the system when you topped it off?
what elevation are you at?
100C is not crazy hot. But it should be greater than 80 when you are running it.
hey, i did not burp it, should i just let if run with the cap off to do that? its taking way more water than i would imagine a burping required though, unless this will cause the water level to be way too low and increase temp....
im in colorado, so high alt. but like i said its maxing out the temp gauge.
im wondering of its the oil too, i changed it a couple months ago, so it should be good and used 10w30 but it was not diesel specific, just said it had cleansing agents in it and such.... should i be using the 15w40 i use in my truck? it is for diesel engines.
   / Operating Temperatures Help Please #8
oil per se won't cause an engine to overheat, but you'd be better off running a good diesel oil such as rotella. Diesels by nature are dirty and regular oil doesn't contain the additives needed for diesels.
As for your radiator overflow dripping, it could easily be a bad pressure cap, or the cap's been replaced with one having to low of a pressure rating. Thermostat could be sticking closed as well.
you can also start it and warm it up with the cap off and dip a thermometer in the radiator to check actual temp.
A radiator shop can pressure check the cap. worst case would be a partially plugged radiator which would require removal and having a shop rod it and get it all cleaned up.
As far as elevation, in colorado you could be anywhere from easten plains at about 4K feet to 8 or 9 K up in the mountain communities, or back down to about 5K on the western slope. so just as an fyi, simply stating your in colo. really doesn't answer tha altitude question.
   / Operating Temperatures Help Please #9
When I suggested he check the oil I meant to make sure there was enough. Plus, looking at the oil can often tell you a lot, as in if it has water, coolant or metal in it. ;)
   / Operating Temperatures Help Please #10
When my tractor starts running hot is almost always dirt/dust in the fins of the radiator. Take an air hose and blow out the fins of the radiator, I bet it will help.
2015 WESTERN STAR 4900 SF (GLIDER) DAY CAB (A53843)
2015 WESTERN STAR...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
2012 FREIGHTLINER CORONADO (INOPERABLE) (A53843)
2012 FREIGHTLINER...
TEXAS PRIDE TRAILER (A53843)
TEXAS PRIDE...
