Backhoe Operating backhoe
   / Operating backhoe #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Hi
At what RPM do you run the engine, when operating the backhoe?
Charlie.
   / Operating backhoe #2
Start out at a RPM that is comfortable for you. That may be at an idle or a little more. The higher the RPM, the more jerker it is for an one that is just starting. As you get more comfortable increase it. Most of the time I run mine at about 1200-1500 RPM.
   / Operating backhoe #3
It all depends on what I'm doing. All hoes are definately not the same. My Woods 1050 has a PTO 10 gpm pump. I usually run between 220 PTO rpm for very careful work like placing rocks to about 350 for fast quick digging. I would say that for most jobs I set up at 330 rpm on the PTO digital tach. I know some tell me that they run at rated PTO speed, but I think that with my setup I'd be too wild at that speed, the 1050 is quick enough at 350. If you are using tractor hydraulics and have a small pump, then perhaps you could run higher.
Andy
Andy
   / Operating backhoe #4
Like others have said it will depend on your comfort level and the task at hand. I spent quite a bit of time on my backhoe this weekend, mostly around 1500 rpm. Adequate speed and plenty of power for what I was doing.
Here's a question for the seasoned hoe operators out there...
I get pretty good at the controls when the work is directly in front of me. I needed to work off to the side in one situation and for some reason I got all twisted up in the controls. Just couldn't make that bucket work like I should have. I suppose it's like flying an RC plane away versus towards you. Any suggestions?
/forums/images/graemlins/smile.gif
   / Operating backhoe #5
Rob,
The best thing that I can tell you is to just do it and don't think about what direction the boom in at. I had a hard time doing the same when I first started. Learning to digging to the side is just like digging in front, practice is the key. After a while you won't even think about it.
   / Operating backhoe #6
I used to run 1500rpm but as I got accsutomed the controls as to how to NOT make jerking movements I speeded up. Especially when swinging the bucket from side to side, if you end the swing with a bucket tilt there will be no jerking or rattle. There are also ways to dig without dragging yourself forward or is it backward. It all comes with experience. Now I run about 2000rpm. /forums/images/graemlins/cool.gif
   / Operating backhoe #7
<font color="blue">Start out at a RPM that is comfortable for you. That may be at an idle or a little more. The higher the RPM, the more jerker it is for an one that is just starting. As you get more comfortable increase it. Most of the time I run mine at about 1200-1500 RPM.
</font>
I agree with Jerry and most of the time I work the backhoe at 1500 RPM.
   / Operating backhoe #8
Hmm, good advice. I wish I'd seen this thread last week. I rented a tractor with a BH on Friday and figured this out by trial and error (aka bounce and jerk).
John
   / Operating backhoe #9
Lazy: ...This isn't aimed at you ,but a newbie should'nt think about reving up the engine over 1000 rpm, untill he masters the feel of the controls ( all of them ) ,then he'll be ready to ease into (12-1500 rpms) /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif ...RayBee /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
And remember to let go of the controls if all goes haywire.
   / Operating backhoe #10
Robs go slow practice makes perfect. learn to watch bucket when can put the teeth where you are looking.then you can go faster. Larry
1997 ISUZU NPR BOX TRUCK (A51243)
1997 ISUZU NPR BOX...
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2013 FORD F150 XL TRUCK (A51243)
2013 FORD F150 XL...
2010 GMC Acadia SL SUV (A50324)
2010 GMC Acadia SL...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
