1S1K
- Joined
- Dec 30, 2013
- Messages
- 15
- Location
- Oregon
- Tractor
- 2012 JD 3720, 1967 John Deere 1020, 1961 Ford 881D, 1952 Cat D4
Hi All,
Can someone tell me how to tell the difference between an open center and closed center hydraulic system, My D4 Cat has an aftermarket pump and valve that are pretty old and I can't easily tell what the pump is. The problem is that the float position on the valve is worn out and its leaking. Also it only has 2 remotes to control the blade and I would like a third so I can run my disc at the rear without unhooking my blade controls. Also, is there a way to figure out how many GPM the system is so I can properly size the new valve? Thanks for the help.
1S1k
1S1k
