Open center log splitter valve or closed center valve?
   / Open center log splitter valve or closed center valve? #1
ALF_HMC
Just south of Knoxville TN
Montana 3440 HST
I have a Montana 3440 hst and just bought the speeco log splitter. Does anyone know if I need to use the conversion kit that comes with it?The conversion kit changes it from a open center valve to a closed center valve. For whatever purpose?
   / Open center log splitter valve or closed center valve? #2
Put a gage in the pump circuit and see if you have constant high pressure. An OC system should read no pressure to very little pressure. .
I'm not a verry mechanical person...how would I do this?
   / Open center log splitter valve or closed center valve? #4
No, Your machine is OC.
O.K. thanks alot for the information and for everyones input.
I have installed the speeco log splitter(oc) and it seems to run good.the legs and frame holding the log splitter needs some beefing up though.I used 2 5ft 4000lb preasure hoses and luckily 2 general pioneer disconnects from tractor supply.
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
Payment Terms (MUST READ) (A50774)
Payment Terms...
Chery 6' 10 Drawer Workbench (A50121)
Chery 6' 10 Drawer...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2012 International 4300 Reefer Truck (A52748)
2012 International...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
