Backhoe OOPS
   / OOPS #1
s78wingrider
Hardy Co. WV
Mahindra 3215 gear
just replaced plastic rod end on bucket, stick control side and was moving both controls around spraying everything with lube when, SNAP. plastic rod end on swing control linkage broke, :mad: hope they have another one in stock, if not, maybe should order a case! It's a 3710 on a 3215. Aaron
   / OOPS #2
Can you replace with metal? Is there an anchor pin (immovable, pivot point) that is broken, misaligned, or spring pin missing?
Wondering if you are over flexing the joystick due to another broken part?
It is also possible that this other part was over stressed when the first one was broken...
Good luck.
- JC
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
DRUM OF MISC HOSE CLAMPS (A51244)
DRUM OF MISC HOSE...
JCB 3TS 8T SKID STEER (A51242)
JCB 3TS 8T SKID...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
