one more ? on power service
   / one more ? on power service #1
whitearrow
philadelphia,ms
john deere 5203
can you add it directily to your diesel tank on your tractor?
thanks,
whitearrow->>>-------------->
   / one more ? on power service #2
The instructions on the bottle indicate that you add a certain number of ounces to a certain number of gallons of diesel. It doesn't matter what container the diesel fuel is in.
   / one more ? on power service #3
Most tank additives recommend pouring the additive into a low tank and then filling it to get some mixing from the nozzle. I add it to the jerry can and then fill from the barrel. Then I dump the jerry can into the tractor tank. If I was fortunate enough to be able to fill directly from the barrel then I would add the PS to the barrel before filling it at the fuel depot. Least ideal would be additive in the tank but I think we are splitting hairs.
Most diesels use a pump through type fuel system where fuel that doesn't get squirted into the engine is circulated back to the tank so the tank gets stirred up pretty good.
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
