One month on synthetic..so far so good
   / One month on synthetic..so far so good #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
I switched my wifes car over last month. It is a 01 Olds Aurora V6 with 75k. I decided to try the Walmart synthetic brand since several people here said it was ok. This car has a special oil filter so I had to order a AC filter from O'Reillys. I changed over right at 75k. I have been checking the onboard computer for sometime and my wife drives the car to work every day the average MPG stays right at 21.7(+or- .2 tenths). It has been very consistent. I reset the computer when I changed the oil and filter. It has been one month and just under 1K miles. I checked the computer for average MPG and it was 23.8. No leaks and runs smooth. I am going to reset and check every month for a while. My tractor is still at only 30 hours since I rebuilt the engine. I think I will stick with dino oil for the first change and switch at 100 hrs. I am still getting a little smoke and using a couple ounces every couple of hours. I don't think I have it broke in all the way. It is a Kioti LK3054 and I have not been able to keep it under a heavy load for an extended period of time. i don't do much but cut grass with it.
   / One month on synthetic..so far so good #2
fyi
Wix 57090 fits the Olds
btw - 32 yrs using synthetics, so far so good.
   / One month on synthetic..so far so good #3
fyi
Wix 57090 fits the Olds, same filter as the Cadillac 2004 up CTS 3.6VVT engine - AC Delco PF2129, about $6. I found Fram model at Walmart for $9.95.
   / One month on synthetic..so far so good #4
Walmart full synthetic is not a group 4 or 5 synthetic (amsoil, redline, etc). It is a blend. For $13.98 for 4- quarts there is not way it is a true synthetic like the ones I listed.
Now, for the price and the item at hand, it is a good oil. I would go around 6 to 7 max (but use UOA to define usuage limits).
Might want to look at Halovine oil. Lots of moly and only $1.98 per qt.
As noted above, Wix is a good filter and so it Supertech
I am not arguing with you...really more asking....I believe Walmarts synthetic says full synthetic on the label. You say it is not a full synthetic? Are they advertising falsely or did I misread the label? Just want too know before next time. I had to get O'Reilly's to get me the filter. They only had a Fram in stock. I could have gotten a Wix, I know they are good filters, but he AC is OEM and it was half the price. What's amazing is I paid $5.69 for the AC, Wally world wanted $9.82 for the Fram and I think the Wix was $9 something. BTW, this is a cartridge filter that goes in the it's on receptacle in the pan, not a spin on.:eek:
   / One month on synthetic..so far so good #6
There is a big argument in the oil community about that. What is a synthetic? Well in technical terms a synthetic oil is any oil that has had the molecules changed in the manufacturing process thereby creating a new molecule. Some would say this is bunk, others say it is. I'm guessing that Chinamart full synthetic is Group III which is made from petro/crude oil but is hydrocracked and has had the molecules rearanged. Is it synthetic, yes it is. Some would say it is not a true synthetic though because it started life as dino oil.
   / One month on synthetic..so far so good #7
No problem. Anything in group3 (hydrocracked dino) or above can be called a synthetic. It is LEGAL to do this based on a court case a few years ago.
There is no ester or POA's in this walmart oil. It is not gonna happen for the price of $2.50 per qt. But you read the label correctly and I have the bottle in front of me! :)
It is a blend and a good oil at the price. It is not even close to group 4 or group 5 but a good deal for the price. I would almost take Havoline for the price delta.
I think WIX online are like 2 to 4 for a oil filter. Go to fleet filters.com
   / One month on synthetic..so far so good #8
Have you every found the 2129 deformed? Last year I changed just the filter on the CTS (was the factory one) after 5,000 miles on the new car and when I removed it, it was shaped like a hour glass, caved in at the center. Filter was made in Mexico. I now got some Wix and they are made in Poland. I paid around the same, $5-6 for the Wix, seem to be a more sturdy filter but we'll see.
The filter on the CTS is mounted on top of engine, is simple to change , no mess at all.
FWIW - This is from the Wal-Mart list of MSDS
SUPER TECH FULL SYNTHETIC - ALL GRADES -- SPECIALTY OIL / PENNZOIL
I will probabbly move up to a real synthetic next oil change. I'll check on the Wix before next oil change also. This is the first time I have changed oil in this car. Been too busy over the summer, I am in real estate. Getting poor now that fall is coming and had to do it my self.
This spring I rebuilt the engine on an abused Kioti LK3054 I picked last winter. I have only put 30 hours on it and it is still using a little oil. Some have told me to run it under a full load and I have tried, but I don't have much that will load it down. I mean most of what I do is just cutting and this thing just ripps right thru it and does not slow down. It starts right up and runs good. I say all this just to ask, how long should I wait before I switch to synthetic. If the rings are not completely seated yet I would not want too, or is my thinking mistaken?
   / One month on synthetic..so far so good #10
It depends on what duration you are looking for. The Supertech might be a good fit. The supertech does have a high Noack rating so you will use some oil. Now if the rings are not seating, there is additional oil.
I would toss a synethetic oil in now. Nothing will happen but longer ring seating. It is up to you wait or not. Either way will not do anything.
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
