"One machine" mentality
   / "One machine" mentality #1
bxowner
Vermont
John Deere 5055e
I have to admit, I'm one of those people that thinks my tractor should be capable of doing (pretty much) every task around my property - instead of one dedicated machine for each separate chore. That's why I chose the B2920 and ordered it with a FEL and MMM to start... with a plan to add a plow and 3-pt chipper later on. I had been debating buying a gear-drive tractor with FEL (JD 3005) and separate lawn tractor or Z-turn to mow.
Well, last weekend, I put on the MMM for the first time and I was pretty disappointed in the mower deck from the start. It's a 60" deck and I have a less-than-level yard, so there was a lot of scalping and tall grass patches. Also, putting it on was a much larger chore than I expected - between the turf tires on my tractor being pretty fat and the width of the deck - and and even though I have long arms (I'm over 6' tall) - I could barely reach the mid-PTO. I began to really question my purchase. That is, until yesterday, when I put on a 48" Woods brush hog and spent 2 hours in the woods knocking down thicket and brush (my effort at keeping deer ticks in check, as my dog is recovering from Lymes Disease). I really appreciated the hydro transmission more than ever - if I had the 3005, I'd still be out there!
I just can't resign myself to the idea of spending so much money on a tractor... and then spending another chunk on another machine. It seems "decadent." Plus, the B-series seat and large tires are so much more comfortable than I imagine a riding mower to be.
So, I guess my point is, for people just getting into a tractor for the first time - which seems to be a big part of this online community - there's something to be said for both arguments. I'm just curious how many people fall in which camp - and why.
   / "One machine" mentality #2
Of all the BX owners, I am, no doubt, in a minority, and that is OK. I chose not to buy the mid mowing deck. The lawn is such a low priority up here. Grass doesn't flourish on our sand soils and rains are rare enough in the summer and the grass goes dormant quickly.
Since I have to get onto the garden dirt all the time, the constant removing and remounting of an MMM wasn't going to happen. Dirt, Snow, Utility. The trinity of my tractor purposes and purchase. Grass wasn't even in the running for part of the equation.
At the dealership, the thought DID occur to me that for the cost of the MMM, I could buy two cheapo Briggs type tractors from in front of WalMart. Let's see, 6 years each, that'd be 12 years. But, I haven't even bought one. :D
   / "One machine" mentality #3
Same boat for me. I do have a CC mower with 48" deck, but I am planning on getting a 72" deck for my B7800 once all the yard work is done. I'd probably keep the Cub thought...it's handy for tight spaces, hauling yard carts around and it does have a snowblower attachment. The Bota could do all that, attachments aren't cheap. When the cub konks out I'll probably get the attachments for the bota, won't be worth buying a new lawn mower.
   / "One machine" mentality #4
I had the zero turn mower before I bought my B2320 but I probably would've had a dedicated mower anyway. I kind of depends on the land you are going to mow. The B2320 is too tall to fit under my trees and there are lots of obstacles to mow around. With the zero turn I'm done in about an hour. If I had a deck on the tractor it would be more like two hours or more. But it is a sizable expense to have another machine to purchase and then maintain so you have to consider all the variables and everyone's will be different.
   / "One machine" mentality #5
Ahh, solutions that bring more problems (-:
If you have that much scalping.... maybe time to rip up the lawn, do some SERIOUS re-contouring to get those NICE gentle rolling curves that have the "right" points of inflexion and....Y' know what I mean.
...and lay a whole new one
Lets see, do you have a box blade (yet) ?
Tiller (yet) ?
Land plane ?
Chain harrow ?
Landscape timbers or old tires to weight the chain harrow ?
Spreader ?
Heavy roller (water filled) ?
Finish mower ? Oh, I forgot, the mmm you have started all this (-:
Tractoring (if there is such a verb) isn't "Mowing".
My current compromise is a flail mower and a seasonal change to turf tires.
After a while "lawn" get rollered down pretty well with about 3 tons on 18 inch
wide tires.
I try to alternately mow with the flail behind the tractor and fully shifted to the right, this pretty much eliminates any tendency to put down tracks.
I don't DO low hanging branches, so no problem there.
   / "One machine" mentality #6
I really don't think it is unrealistic to expect to be able to have one tractor "do it all" depending on what all you do.
I have several hundred acres in different locations and there is no way one or even two tractors will do all that. I am retired, but don't want to spend all my time driving or hauling equipment back and forth; did that for a few years, but I was a lot younger then.
Now my wife might be mowing with a John Deere or Kubota while I am bush hogging or doing FEL, box blading etc. with my Kubota, Case or Massey Ferguson. Funny how bored people told us we would be if we retired.
   / "One machine" mentality #7
One machine mentality: A properly equipped BX or B can usually do all the jobs of the average homeowner in a very good to outstanding manner. Implements are necessary to accomplish this task. The jobs these machines can accomplish are innumerable and people are discovering new abilities daily for them. If Kubota will add weedeater string to come out the front, rear and side then they are the only machine the average homeowner should ever need, since that option is not available at this time a weedeater, push lawn mower or Grass killing solution is usually required for edging.
I have 3 plus a push mower but I use or will use 2 of them at a rental property when I get my hole digging done here at home.:)
   / "One machine" mentality #8
I fall in the bp camp. I bought a BX this spring, no MMM, only FEL and ballast box. We have all sand/gravel here, every time i've attempted to add top soil it ends up at the end of the drive. Usually by late summer i'm only mowing once every three weeks or so. My resolution is a 700 dollar garden tractor, and as bp stated I could go through a few of them before I paid for a MMM. Everytime it rains a new crop of egg to softball size rocks appear, not what I'd like to be mowing with an expensive mower deck. Don't know that the BX will ever see a mower deck on my property.
   / "One machine" mentality #9
I have both a large riding mower / garden tractor, and a B series Kubota. I have come very close to ordering a mmm for my B on two occasions, but at the last minute I did not. While I have a love / hate relationship with the full length rear roller on the Simplicity mowers, they do an excellent job of following my rough 3+ acre yard. (Before folks bring it up, my yard is so full of rocks poking through, and just under the surface that it would take major equipment, and a lot of money to smooth it. A great many of these "rocks" are much too large to budge with my B.) Every time I get close to the MMM thing, I use the garden tractor, and find that I would want something more manuverable, not less, given a choice. I use the garden tractor to pull a trailer when I'm chipping around the yard, and for many other tasks that make a Zturn not viable. The Simplicity is 10 years + old now, and I'm thinking about replacing it. Just last week, I came close to getting the mmm for my B to make the Simplicity last longer, but in the end I shot the idea down. If I had just one, it would have to be a BX sized machine, but they are just a hair too heavy for ideal yard work, and low for my woods work. Two is best for me, and I expect for most folks. When I bought the 2wd Legacy 10 years ago, I hoped I could do everything with it, but found out very quickly that it wouldn't suit my tractor needs. Just to use the Cat "0" 3pt required removing a bunch of stuff, mounting the thing, and climbing under the tractor to switch the hydraulics to the rear. ( none of that needed these days), and it just didn't have the weight, and traction needed. I also discovered rather quickly that any attachments for it were the same price as "real" tractor attachments. Next, I bought a used BX22, and for many if not all yard chores, it was the ideal pair as JohnThomas is discovering. I could dethatch with one, and collect the chaff with the other. Both were highly manuverable. The BX really wasn't quite large enough for some of my "tractor" tasks though, and so I moved on to the larger B. If I had it all to do again, what would I do? Well, if I were certain about that, I probably would do it! :D :D I have a fair amount of backhoe work I could do, but don't need to. If I decided to do that, I would get a larger B for the better backhoe, and a slightly smaller mower than the big Simplicity probably. My 3pt snowblower is overkill for my needs, and I have a little cancer in my back now that makes it a bit harder, but not really painful to use. I would seriously consider a blower on the garden tractor which would be a lot cheaper than a front mount for my B, and leave me the full use of the loader for nasty sloppy stuff. I've just ordered a tiller for my B since they are not much more than a good walk behind, and the same price, or less than one for a garden tractor. Material collection is a big deal for me so any mower needs to have an easily mounted effective collection system available. The ones Kubota makes work OK I guess but are a pain to mount. The new one for the B just makes me shake my head in disbelief. The engineers must think it will be mounted for the life of the tractor. OK, Too much, or not enough coffee this morning I guess............. sorry guys.
   / "One machine" mentality #10
Since you have a B series, perhaps a MMM is not the answer for you. Have you considered a RFM instead ? it has 4 wheels on each corner with antiscalp in middle front and back on the good models. It might work better in your situation for mowing. Adding a quickhitch will allow you to swap implements quickly, all you gotta do is connect/disconnect rear PTO which should be easier for you then MMM PTO on a B series.
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
434669 (A48836)
434669 (A48836)
