Onan Ignition Module Gone Bad! Real Bad!
   / Onan Ignition Module Gone Bad! Real Bad! #1
1966vette
Hello Wheelhorse / Toro owners!
I'm having problems w/ my 16hP Onan Wheelhorse 616-Z ZTR.
The engine runs fine when cold but shuts off when it gets hot.
I already replaced the coil because it tested as defective but the cutoff problems still exist.
I ran 12 volts to the + side of the coil & still no spark. This indicates that the oil pressure sending until is not the problem.
I'm looking for any tips that maybe helpful when I remove the blower housing cover & flywheel.
I'm also in the market for an ignition module for the Onan P216V / 10873A engine.
Thanks!
Andy
   / Onan Ignition Module Gone Bad! Real Bad! #2
I have a Wheel Horse 416-H with a Onan 16 HP.
I had the same problem, when the engine got hot it would turn off just like turning off the ignition. I changed out the coil, which did not fix the problem. I then changed out the ignition trigger underneath the flywheel.
Its been running great since (15 hours plus).
The coil and the ignition trigger were both around $80 -$90 each thru Onan,
but Wheel Horse was even more expensive.
Only tip I can offer is try and allow enough time to disassemble and reassembly all at once.
I did so that my short memory was still fresh enough to reassemble everything.
I was pretty pokey when I did the fix, but still only took a couple of hours.
Some sought of puller for the flywheel would be handy too.
Sorry but I just noticed 1966vette post was an old post 05/29/10.
   / Onan Ignition Module Gone Bad! Real Bad! #3
I just got a 416 hydro with 2 cyl onan, no spark at all. What would you advise me to try first? Do these have points and condenser?
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
2011 INTERNATIONAL PROSTAR TANDEM  AXLE MID ROOF SLEEPER (A54313)
2011 INTERNATIONAL...
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
