Oil & Fuel On the subject of oil changes, while I hate to admit it.
   / On the subject of oil changes, while I hate to admit it. #1
Chuck K.
Texas Gulf Coast
2009 M59 w/thumb
Just a friendly FYI.
Dont get in a rush like me...... Be sure and drain the oil from BOTH drain plugs :mad: :eek:
Was wondering why 9 quarts overfilled it, talk about feeling stupid.. I use to be an auto mechanic and Ford was notorious for double sump oil pans that had 2 drain plugs..
Oh well I will change the oil again on my next days off........
   / On the subject of oil changes, while I hate to admit it. #2
Dont get in a rush like me...... Be sure and drain the oil from BOTH drain plugs :mad: :eek:....
And in the case of the Transmission/Hydraulic fluid (AKA UDT) all THREE drain plugs :)
FWIW I suspect that experienced mechanics are more likely to make this mistake because they don't read the manual as carefully as a NOOB ;)
Talon Dancer
   / On the subject of oil changes, while I hate to admit it. #3
Don't feel so bad. I changed mine the other week and forgot to put the drainplug back in! Yes, you guessed it. It took twice the amount of oil to fill it back up. That get's expensive. Thankfully, I never try to crank them over until I see signs of oil on the dipstick.
And yes, I used to be an ASE certified mechanic.
T.D. I think you hit the nail on the head:
This probably makes me more dangerous LOL..
And D.D. I was guilty leaving plugs out a couple of times when I use to wrench years ago.. The most exciting thing though was leaving a fuel line loose after rebuilding the carb, and as luck would have fuel spayed found bad coil wire and I had a nice fire in seconds... The good thing was I alway kept a large CO2 fire extingusher in my stall and had it out in less then a couple of seconds but it sure made for a lot of excitement..
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
1996 CATERPILLAR 416B BACKHOE (A51242)
1996 CATERPILLAR...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
2002 KOST MH (A50324)
AYLEID HOSE REEL, SPRINKLER (A51244)
AYLEID HOSE REEL...
