evisr8
i have a 609 deere rotary mower. the shear bolt (grade 3) on the pto drive shaft keeps shearing. apparently, the 609 has a slip clutch. can i use a grade 5 bolt for the shear bolt?
evisr8 said:i have a 609 deere rotary mower. the shear bolt (grade 3) on the pto drive shaft keeps shearing. apparently, the 609 has a slip clutch. can i use a grade 5 bolt for the shear bolt?
Z-Michigan said:I'm a bit confused - if you have a slip clutch you should not have a shear bolt. The slip clutch may be under a plastic cover but it should be pretty obvious due to its size. Does your particular 609 cutter have a slip clutch?
