3-Point Hitch Oliver 770
   / Oliver 770 #1
Oliver 770
Newport,Nova Scotia
Oliver770, 1964 MF Backhoe
I,m fixing up an Oliver 770 wheatland tractor and at the present time doesnt have any hyd. on it. Just a draw bar. Is there anyway I can install hyd. 3-point hitch on this tractor,if so any info would be appreciated.Thanks
Scotty
   / Oliver 770 #2
Scotty,
I assume your 770 has pto and this drive from flywheel shaft should have splines to drive any hydraulic unit from any 77-880 which bolts above transmission under steering wheel. Pto has to be pulled half way out rear (3 bolts) as shaft goes thru hyd gear pump. Because of this these pumps are unique to overhaul. Seals are available ,but if you need new gears I know of only one source near Brodhead WI.
AL1
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2023 JOHN DEERE 8R310 LOT NUMBER 198 (A53084)
2023 JOHN DEERE...
UNUSED HURRICANE 5' X 10' CONTAINER (A51248)
UNUSED HURRICANE...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
