29toter
I bought an Oliver 1800 a little while ago the fluids were freshly changed. I drove it home (about five miles) all was fine. Used it for brush hogging about two hours and all was fine. Started using the hydraulics to pull fence posts (about 40 minutes) and I noticed a white milky substance dripping out of the governor. I shut her down immediately and checked the oil, (slightly milky). After this I was unable to get back and look into it for a while (ten days). When I did, I checked the oil again and it seemed less milky and darker than it had been before. Not black but definitely not new oil color. At this point I checked compression. Now I know the procedure is to warm up the engine but I was afraid of running the engine with contaminated oil so the test was done on a cold engine. All plugs were in except for the cylinder being tested. This is what I found.
Cyl #1- 175 lbs
Cyl #2- 175 lbs
Cyl #3- 170 lbs
Cyl #4- 170 lbs
Cyl #5- 170 lbs
Cyl #6- 165 lbs
All cylinders reached this pressure in three or four turns and held pressure for 2 minutes after. The engine never skipped, never missed and didn't bog down. Also there was no smoke from the exhaust.
Can anyone give me a clue as to what could be wrong? Or where to start looking and/or any test procedures to help me narrow this problem down?
Thanks everyone
Cyl #1- 175 lbs
Cyl #2- 175 lbs
Cyl #3- 170 lbs
Cyl #4- 170 lbs
Cyl #5- 170 lbs
Cyl #6- 165 lbs
Thanks everyone
