Older Tractors w/ Loaders
   / Older Tractors w/ Loaders #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
I currently own a JD 5103, 2005 model with about 190 hours. I have toyed with the notion of putting a loader on it but after getting several prices, all around 6k, I've decided to look for a decent used tractor. I would like something close to the same power as my 5103 (50 hp) and maybe 4wd. I would like to spend less than 8k if possible. I plan on keeping the 5103 for bushhogging and mowing and using the 2nd tractor for dirt work and discing. Any thoughts on makes/models? Age is not a huge factor, but would like to stay late 70s on up and diesel powered only.
   / Older Tractors w/ Loaders #2
were are you loacted? i have a 2wd, 584 International, diesel, with a loader. 60hp. nice little tractor
About 50 miles north of baton rouge, la. Send me some pics of it if you have some. That is right about the size I am looking for.
   / Older Tractors w/ Loaders #4
Check out tractorhouse.com. There is a lot of good older tractors out there fairly priced. You can look at all the tractors in the HP range you want and enter your zip code at the top of the page and it will list them in order of distance to you.
Engel 20' Boat (A50121)
Engel 20' Boat...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53473)
2017 Ford F550...
Skil 5 speed Small Drill press (A53117)
Skil 5 speed Small...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
