Older Tractor痴 and Retaining HP
   / Older Tractor痴 and Retaining HP #1
dieselscout80
Veteran Member
South Carolina
New Holland TC45DA
How well do older tractor’s retaining their HP?
I have old IH 424 diesel tractor from the 60s that’s rated for 36.97 PTO HP.
TractorData.com International Harvester 424 tractor information
It still runs good, but I don’t have a reference to know if it’s still producing it’s rated power.
Any ideas on what to factor for HP loss?
   / Older Tractor痴 and Retaining HP #2
If it's running good without excessive smoke and doing the work you ask it to must be all right.
If you really want some numbers call up your old line dealers and see who has a PTO dyno and have them
come and test your tractor, they could check your pump pressure and timing run the dyno test maybe even tweak it up a bit.
   / Older Tractor痴 and Retaining HP #3
Hook a 3 bottom plow on it.
   / Older Tractor痴 and Retaining HP #5
If you determine current horsepower accurately it will tell you nothing about pressure decrease in hydraulic cylinders do to wear, nor increased pivot pin friction.
   / Older Tractor痴 and Retaining HP #6
There are PTO dynamometers. Some tractor dealers have them. You could find one and run yours on it. But without an as new (or just broken in) run you only have the spec to compare with. Actual values can differ due to production tolerances, not to mention purposeful inflation or deflation of the rated number.
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2024 JOHN DEERE FC 10 R LOT NUMBER 84 (A53084)
2024 JOHN DEERE FC...
LINDE H70 FORKLIFT (A52472)
LINDE H70 FORKLIFT...
100 GAL FUEL TANK (A52472)
100 GAL FUEL TANK...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2008 KOMATSU D39PX DOZER (A52577)
2008 KOMATSU D39PX...
