Older L775 New Holland Skidsteer - another "what fluid can I use" question
   / Older L775 New Holland Skidsteer - another "what fluid can I use" question #1
befiendly
Seattle WA
New Holland
I recently acquired an older l775 I want to flush out the systems. Specs call for 90 wt in the gearcase and chaincase and Only Dextron II ATF in the hydraulic reservoir. It has been sitting and I would like to run it with "cheaper" oil/fluid for a week/month or 2, then change fluid again. I am wondering if I can use "universal tractor fluid" or equivalent ($40/ 5 gallon) in the hydraulic system instead of ATF? The bobcat dealer also says if I want to rent their auger attachment, I have to use hydraulic fluid not atf. Would it be detrimental to run the "tractor fluid" long term?
ALSO: How about the same tractor fluid in the chaincases? any possible damage to seals etc?
Advice much appreciated. Thank you!
2004 20ft Explorer Pontoon Boat and Trailer (A51573)
2004 20ft Explorer...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
