Older Gas Engines
   / Older Gas Engines #1
Piperflyer
USA
Kubota3030HST
What precautions, along with what should we be doing when we run our older gasoline motors on this new ethanol fuel?
   / Older Gas Engines #2
No problem with running it, its the storage and getting it to the motor. I would put a new fuel line setup on it ready for ethanol crap. Put a fuel shut off on it near the carb or whatever it has, and a fuel filter within 6" of the carb.
It attacks the rubber and metal parts on the system the most. If its seldom used piece of equipment I would use the fuel shut off to kill the engine by letting it run itself out of fuel when done to protect the carb.
I have ran into more than 10 times that a carb was gummed up and the fuel line going to it looked brand new. I took that line off and sliced it open with a box knife and it was softened and breaking down internally.
Chris
   / Older Gas Engines #3
yep. really old engines might require a carb rebuild.. and if on rubber lines.. be prepaired to repalce them.. along with diphragm fuel pumps and such.
I remember when bio-blend diesel hit. had to go around and repalce orings in some of my diesels..
soundguy
   / Older Gas Engines #4
I also prefer to top of the tank after each use.
Chris
   / Older Gas Engines #5
yep.. I do that now.. less room for air and thus water to condense.
PS.. my 6.0 ps has been fine since purging water from the tank.. just had a real wet tank there for a couple weeks
   / Older Gas Engines #6
Glad you got that straitened out.
Chris
   / Older Gas Engines #7
it was a pita a total of 3 times for me.
have confirmed and quad checked.. no coolant loss.. and no oil emulsion.. so egr and hg seem ok.
may still get the egr eliminate kit. have not ruled that out.
DO think I might have a bad glow plug or two though...
soundguy
   / Older Gas Engines #8
yes i work on lawn mowers at my shop and the main parts distrubtor for us came by the other day and we was talking about the 15 percent stuff and he said to start changing all fuel lines and like diamondpilot said put in a fuel shut off valve and if setting over winter to drain the fuel because if not u will be buying a carb if not a motor.
2013 F-550 Bucket Truck (A55218)
2013 F-550 Bucket...
2023 Top Hat Industries Cool Down Trailer (A52377)
2023 Top Hat...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2020 Deere 325G (A50123)
2020 Deere 325G...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2014 Ag Spray Schaben Sidedresser (A55301)
2014 Ag Spray...
