Older fiberglass insulation rating?
   / Older fiberglass insulation rating? #1
USAFpj
SC
1957 841 Powermaster
In attempting to rate the different insulation types- who has an idea what the 'typical' metal building insulation was in the early nineties? This is yellow batting, 3 inch, has a white vinyl backer that faces the interior, and like today, comes in long and wide rolls. We're attempting to find out what the relative "R" rating was for this type.
   / Older fiberglass insulation rating? #2
I've heard numbers from 6 to 10. My guess is 6 is closer to accurate.
   / Older fiberglass insulation rating? #3
4 inches of pink insulation that were used for walls in the 70s was R12, if its 3 inch it would be about R9.
   / Older fiberglass insulation rating? #4
If I recall correctly, 4"=R8 and 6"=R12.
I'd bet in steel building with the vinyl bagging it was R4 at best.
The main aspect was that the vinyl 'bagging' prevented sweating being an excellent vapor barrier.
Steel buildings will sweat from humidity and their goal was to prevent that at a minimum cost. Hence bagged 3" of insulation.
Adequately efficient for a storage or minimal usage building but not so for a dwelling.
Unused 10 Ton Electric Cable Winch (A52378)
Unused 10 Ton...
2011 Nissan Maxima Sedan (A55758)
2011 Nissan Maxima...
LOT LOCATIONS (A54607)
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
UNUSED LANDHONOR LHR-SB2T3M CHAIN LEVER HOIST (A54757)
UNUSED LANDHONOR...
2025 LandHonor LHR-TWP80 3in Semi-Trash Water Pump (A52378)
2025 LandHonor...
