Old Tractor John Deere 2550
   / Old Tractor John Deere 2550 #1
jose60
Brampton,Ontario
John Deere 2550
Hello everyone;I am a newbie in the tractors area.So here is the question I purchase a JD 2550 in a decent shape,but is no decals or manual operators, I having trouble with the gears selection (all the cars I drove where manual) the previous owner point this; right side stick is your 1,2,3,4 and your left hand stick is 1,2,3,4 high and lows and reverse is a left handed steering wheel (help anyone?)
Also I have a very bad cluster plastic or glass? all full scratches cant see trough it, but works and last is no lights at all the somebody out there has electric diagram for this particular tractor.
   / Old Tractor John Deere 2550 #2
You should be able to go online to J Deere parts and get information on this tractor. You can get parts diagrams and information that is very helpful. John Deere - Parts Catalog
Also see tractordata under transmissions for a little more help. TractorData.com John Deere 2550 tractor transmission information
I should also mention there are several transmission options for a 2550 and you really need to take the model and serial numbers in to find out what you have. I suspect that some had high low ranges on the left side of the steering wheel and others such as 2wd open station could have a direction reverser in lieu of the high low. I noticed that Tractordata mentioned that the reverser transmissions were not available with 4x4 or cab tractors.
   / Old Tractor John Deere 2550 #3
parts key #1 L35519 LABEL 1 X X WITHOUT SGB
parts key #20 L36066 LABEL 1 X X FOR SGB
parts key #21 L35520 LABEL 1 X X WITHOUT SGB
   / Old Tractor John Deere 2550 #4
I noticed in 2550 parts catalog that MFWD or SGB(cab) wasn't mentioned on pages for hyd reverser
Thanks for the decals that can help me a lot
Yes,thanks I allready have look a that webside I will try to find the manual
   / Old Tractor John Deere 2550 #7
JD's phone # 800-522-7448
Operator's Manual OML55481 2350, 2550 Tractor English
Technical Manual CD-ROM TM4403CD 2350, 2550 Utility Tractor
Thanks Jim, I have order one operator manual ($50)
Thanks for the info
USA 36" 9.5T Excavator Bucket (A42203)
USA 36" 9.5T...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A44391)
New/Unused 7ft 20...
2014 WESTERN STAR 4900 TRI AXLE (A45046)
2014 WESTERN STAR...
BOBCAT S175 (A45333)
NOV HYDRA RIG PIPE STRAIGHTENER (A45046)
NOV HYDRA RIG PIPE...
John Deere 72in Worksite Pro BA72 Hydraulic Angle Broom Attachment (A42745)
John Deere 72in...
