old tobacco setter help id
/ old tobacco setter help id #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
i have been looking for an old tobacco setter to restore and use behind my jd that was my grandpas. i have come across this unit and was looking for an id of it manufactorer preferrably. i'm from the ct river valley area, so i'm not sure if there were local makers of these out here and if they're different than the units down south. thanks for any help, jim
PA050022 on Flickr - Photo Sharing!
PA050021 on Flickr - Photo Sharing!
/ old tobacco setter help id #2
My Granddad had 1 just like it. When I was 10-12 years old I set tobacco on that transplanter over many acres, however, I dont remember the brand? Ken Sweet
sweettractors, how does 1 use this type of setter in my pics? i have sat and done work on the type where you drop the transpalnt into a tube when the wheel comes around. is this the type that puts a water spot down and then you drop the plant in the hole? either way for $50 i think i'm going to get it and restore it and then hook it to my jd h, as something a bit different than the norm for my parts, almost all the tobacco and veggie farms in the ct valley used farmalls.
/ old tobacco setter help id #4
Can't help with the ID but know of another in South Windsor CT. MY BILs friend dragged one out of an old tobacco shed where it laid unused since the late 60's on his families land. After they got it cleaned up his 83 yo great grandmother rode on the back & taught them how to plant. She planted with it drawn by horses as a child. If you take a ride over to South Windsor you'll probably find someone planting or that has just finished. MikeD74T
/ old tobacco setter help id #5
I am not sure if the water ran all the time or just when the plant was inserted into the slot. Powell is the only name I can come up with and don't hold me to that. You can put other crops in the garden or truck patch with these type machine. Just drop the seed inthe slot and the machine does the rest. Ken Sweet
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
CAT D8 (A58214)
CAT D8 (A58214)
2010 GMC Acadia SL SUV (A61569)
2010 GMC Acadia SL...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
4 11Rx22.5 Semi Tire Rims (A62177)
4 11Rx22.5 Semi...
John Deere 1025R Tractor (A61166)
John Deere 1025R...
