old Lawn Machine transmisdion
   / old Lawn Machine transmisdion #1
sliderule
Lamar, Missouri
Lawn Machine
I have an old 1997, 20 hp Lawn Machine with manual trans, shift on the go 7 speeds. Always in garage and use weekly either to mow or haul firewood.
Very slow or not at all will it go forward. All pulleys stop, all belts stop between motor and rear trans, pulley on motor shaft marked with no apparent soldering key sheared. Trans not available at MDS and new hydrostatic do not get raving reviews. Any ideas as repairs?
Motor is Briggs and running well. Deck could use new spindles, all else serves serviceable.
   / old Lawn Machine transmisdion #2
:welcome:
From Texas
   / old Lawn Machine transmisdion #3
I am making an educated guess but I think you have the vari-speed drive system made by MTD and used by many companies as an alternative to hydrostatic systems..
There are two special type v belts going to a special pulley system in the middle of the tractor.
The rear transmission only provides a low-high raange choice and all other speed selections are done within the var-drive system.
You tube has a wealth of info on how these systems work and how to troubleshoot and fix them.
Below is a link to one to get you started.
https://www.youtube.com/watch?v=KFar2Ez10Wk
Pulling back on the brake pedal with the top of your foot may bring about an increase in speed just to confirm that all components are not completely broken.
Check further and post back.
The following forum also has some good tips on this drive system.
http://www.lawnsite.com/showthread.php?t=251920&page=2
Dave M7040
Thank you. You are correct about the drive and clutch system. I will investigate the two links. Again thanks.
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2003 John Deere 310SG (A47477)
2003 John Deere...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
UNUSED LANDHONOR LHR-MS0608 METAL SHED (A54757)
UNUSED LANDHONOR...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
