Old Iron Meets New Kubota
   / Old Iron Meets New Kubota #1
Kevin_mc
Bronze Member
East-Central Missouri
Kubota L3010HST 4WD
The learning curve seems to get a little steeper for me each week. When I attached the old 2-bottom Dearborn plow I purchased 3 weeks ago to my L3010HST I did not get it lined up correctly. After several passes in the field turning over a cover crop I raised the plow up higher than or previous turns and the iron that the front coulter hangs on bent the adjustable lifting arm on my 3-pt hitch.
The lifting arm would no longer raise up or down with the crank. I called my dealer and asked for the adjustable lift arm assembly. He laughed and said you're going to want to repair the one you have. I asked how much and he said a new assembly costs $561. He was correct I did want to do the repair.
I took the lift arm assembly apart and found two pieces damaged. The replacement parts were a total of $183 and I am still waiting for them. Should be in this week
This post will be my 10th and should take me from "new member" status to "member". I hope the other "new member" out there don't have to pay the same dues that I did.
Kevin
   / Old Iron Meets New Kubota #2
Heard a guy picked up a box blade with scarfiers extended and the top link came loose and punctured both rear tires before he realized what was happening. Cost about $1000 plus unmeasurable pride!
You will find that most of these problems decrease as your experience (or foresight) increases. Just realizing that if that 3/8 chain was to get caught on a rear wheel it would tear something up completely in less than one second makes you much more careful that THAT accident will be avoided. Tractors give you a lot of power, torque, and work savings but in return they can cause tremendous damage in a hearbeat!
Polaris ATV (A50324)
378811 (A51573)
378811 (A51573)
2015 FORD F350 SERVICE / MECHANICS TRUCK (A52576)
2015 FORD F350...
Polaris Sportsman 335 4x4 ATV (A51573)
Polaris Sportsman...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
